Question about Sewing Machines
Baste stitch setting for a white model 1523 - Sewing Machines
  • Sewing Machines Master
  • 7,365 Answers
Here is a free manual just click on the link, any stitches the machine
makes will be in the manual
http://www.singerco.com/uploads/download/1088_white-1523-x.pdf
Posted on Dec 11, 2012
  • 192 Answers
SOURCE: Husky 165 - won't do a basting stitch
Set the machine to its longest stitch length, put it in the warmest room in your house and in the sun if possible. If the stitch gets longer when the machine is warm it needs to be cleaned and lubed so that the stitch length mechanism moves freely.
If the lube in the machine is getting old or is nonexistent, the reverse button may be depressed and appear to return to its original position, when released, but the mechanism inside the machine only returns part of the way causing the length to be shorter than normal. Heat often masks this problem allowing the mechanism to move.
Posted on Nov 14, 2007
sew dutch
  • 24 Answers
SOURCE: I have a Necchi free arm mechanical sewing machine
I could not think of another way then free-motion sewing.
Drop the feed dogs, and put a spring loaded needle on.
Posted on Jun 29, 2009
  • 23 Answers
SOURCE: How do I get my model 385-19233400 sewing machine
Put the dial on the largest # - like normal is 2.2 and basting is 5 on mine.
Posted on Feb 13, 2010
  • 1788 Answers
SOURCE: What settings do I use on my singer 6038c to make
Use the longest stitch length and loosen top tension,. Practice on a piece of scrap material until you are satisfied with the results. Good luck
Posted on Oct 24, 2010
  • 1788 Answers
SOURCE: How do I adjust the
Make sure that your top threading is right. My sister in law has this same machine and it is a really hard thing to do, Your manual has very vague instructions but check your thread going through the tension discs by pulling on the top thread with the presser foot up, it should pull smoothly, now put the presser foot down, it should barely move. /Sometimes this seats the thread in the tension discs. She is having no luck with the buttonhole making. In 50 years of sewing I have never seen a more vague manual and no customer service at all.
Posted on Dec 05, 2010
Is the Kenmore sewing machine 15343 able to do a baste stitch? If so, how?
A baste stitch is basically setting the machine to a straight stitch with the longest stitch length available. Loosen the top tension slightly if you want to remove the basting later.
May 12, 2017 | Kenmore Sewing Machines
What are the correct settings for basteing on an elna excellence 730
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
Mar 12, 2017 | Elna Sewing Machines
I want to baste and dont know how to set straight stitch and length.
To baste, set the stitch length as high as possible (zero is a non-stitch length, probably 4 or 5 on your machine is the largest stitch length). Set the stitch width to zero so there is no zig-zag.
Jan 09, 2017 | Sewing Machines
How do I set the machine to do a basting stich
if the machine can do a basting stitch the information should be in the sewing machine manual, if you don't have a manual, add a comment with the name and model number of the machine and someone should be able to help you find one.
or you can also try youtube for a video
May 11, 2016 | Sewing Machines
How can I do basting stitch for machine embroidery?
Some machines have a built-in basting stitch. If yours doesn't have it, the closest you can get is setting the stitch length to as long as possible. To make the basting stitch easy to remove, loosen the upper tension. Then to remove the thread, just grab the bobbin thread and pull.
Jan 28, 2016 | Sewing Machines
How do I set the basting stitch length? when I try, it just beeps at me.
A BASTING STITCH IS ONLY A LONG STRAIGHT STITCH. THE NUMBER THAT IS LOWER IS A LONGER STITCH (FEWER STITCHES PER INCH). YOU WERE LIKELY MOVING YOUR NUMBER HIGHER. AFTER YOU GOT TO A CERTAIN NUMBER IT NO LONGER QUALIFIES AS A BASTING STITCH BUT A STRAIGHT STITCH. USE A LOWER NUMBER AND IT WILL LIKELY TO STOP THE BEEPING.
Sep 30, 2014 | PfaFF Sewing Machines
Www whitesewing com
Straight basting stitch (stitch width of 0 and stitch length of 4.)
Jul 22, 2014 | White Sewing 1740 Mechanical Sewing...
Setting for the baste stitch on a white 1523
here is a free manual,, all the stitches the machine can do should
be in the manual
Dec 11, 2012 | Sewing Machines
I am wanting to set my machine (quilters dream 6603) for the best basting stitch I can. I am having trouble figuring out how to set the machine. Thanks.
I haven't been able to find a 6003 manual or a good image of the stitch range for this machine on line. However, a basting stitch might look like " . _____ . _____. " on your stitch selector. As your machine is targeted for quilters I'd have expected it to have a basting stitch in its range.
If there is nothing like that, then just dial up the longest possible straight stitch, ie take length up to 4 or 5, whatever the maximum number is. Then loosen off the top and bottom tensions and stitch away.
If you are using this to baste a quilt top, botton and batting together, I've discovered a product called "spray basting" which is fantastic and "glues" the layers together while you sew them. You need a big clear floorspace though and put paper down under the project. But it works great.
Trust this is of help to you.
Apr 12, 2011 | Elna Quilter's Dream 6003Q
I need to know how to find the basting stitch on my ex660
The basting stitch is not normally a separate stitch, just set the stitch length as long as it will go, and the same for the stitch spacing. Make sure you are not using any fancy setting or zigzag and this should be fine for basting.
Mar 14, 2009 | Sewing Machines
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
