Question about Intel D945GCCR Motherboard
Audio i m using inteld945gccr motherboard my problem is that the front audio port work properly but the inbuilt audio port is not work where the mic port is proprly work of the built audio port please help me..........
    President:
  • 2,351 Answers
Ajayiht22,
If this is the first time you are attempting to use the mic, it must be setup through control panel. Open control panel. Find & open the icon, Sounds and audio decives window will open. Once opened click on the Voice tab. At the bottom of the the window is a button, " Test hardware ". Click it. Follow the instructions from the next few windows. You can not use both front & rear ports at the same time. The ports that work for sound will work for mic once it has been set up.
Posted on Jan 22, 2009
I set up my web cam and i hear my sister when she talks but she cant hear me
well the first thing that you got to check is that if the web-cam has an inbuilt mic to it
If there is no mic then you will have to attach a seperate mic/headset for voice
Also check if its USB port or normal Audio/Video output...if it had audio/video cable then you will have to attach both the cable to the correct port in the Cabinet
If it has USB output cable with inbuilt mic then try to unistall and reinstall the driver software and attach the the webcam only after installing the drivers
Jun 14, 2010 | Logitech Webcam
I got problem to input sound on g31 motherboared, please guide me how can i input sound in g31 motherboard>
The G31-M7 TE MB has a intergrated sound chip.
Enter the bios. Open Chipset. Open South Bridge configuration. Find Audio controller. This should be set to [Azalia] Save and exit the bios.
Next check JAUDIOF1: found on page 14. If you are not going to use the cases front audio and mic than there should be a two pin jumper covering pins
5 & 6 and pins 9 & 10. If you're case supports front audio / mic ports, (You can not use the front audio ports and the rear audio ports at the same). time). Once everything above is set, got to Biostar and download the audio driver software;
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=363
If you still have a problem with you're sound. Explain any actions you have taken.
Mike
Jun 06, 2010 | Biostar G31-M7 TE Motherboard
Mic problem
Is there any device in device manager that has a question mark beside it? Also, is the mic plugged into the right port?
Oct 29, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No audio sound, mic doesn't work.
For audio please install the mother board audio drivers for your PC. The driver cd is provide with motherboard when it is purchased. If this doesn't work, try connecting the speaker jack to front panel of your cpu.
For mic to work properly, make sure you connected the pink color jack of the speaker to the pink port of the cpu(Back side of cpu).
If did nor find drivers, download it from the internet by giving the motherboard type and the number.
I hope it should work now. Thank you
Sep 06, 2008 | Computers & Internet
Sound issues
both ports are integrated audio, both feed off the motherboard, the front ones come off a combo header with hd power lights,
on the back you should have 4 speaker out (surround sound), line in, mic in, 4usb2, 1firewire, 1ethernet, 1parallel, 1vga, 1rgb, 1ps2 keyboard, 1ps2 mouse
fffaab4.jpg try a different speaker out,
you may be attached to one of the fillin ports for speakers that go behind you in surround sound
pink is mic
light blue is line in
light green is headphone/plain stereo
yellow is subwoofer
dark grey is wide
light grey is rear
Jul 18, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Mic issues
A8V-VM SE FRONT PANEL AUDIO does not work. The back panel audio speaker port works ok but not the MIC port. I have built over 100 pcs with different motherboards & procesors including several other Asus MoBo both Intel and AMD types. BIOS flas did not help. Asus tech support /knowledge base is useless to find answers.
If anyone has had this problem and solved it , please pot your answer.
Thanks
Oct 22, 2007 | ASUS A8V-VM Motherboard
Intel D945GCCR Motherboard Logo
97 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
