Question about Jacuzzi Home
Hot water is very slow coming out spout. Cold water comes out fine with good pressure..
Why does the hot water come out the Moen spout slowly while the cold water comes out with good pressure?
    New Friend:
  • 51 Answers
The anti scald is adjusted too low. its located under/behind the handle. it usually has am allen wrench head. remove the handle and adjust it all the all the way to hot that should fix it. on some models you can remove the entire thing,but on some that will cause the handle turn 360deg because in some models its also the stopping point of the handle. hope this helps
Posted on Dec 18, 2012
gina_marrone
SOURCE: my moen single lever pressure
The reason is cause the cartridge is installed upside down, I know this because I just did it and had the same problem, if you look very closely at the cartridge you will see an H and C they will be upside down
Posted on Jun 17, 2012
geo5734036
  • 528 Answers
SOURCE: my hot water in the
Your water heater pipes may be clogged - if your water heater is more than 7 years old you may need to replace it. Visually inspect your water heater to see if there's any visible rust near the bottom or a slow leak. If you are on a well as opposed to city water, Rust is probably your culprit. If it's electric, remove the covers and check out the elements there - there should be a small amount of rust visible if the heater is old. Gas units are very different in construction, and changing a water heater is not exactly an easy job - I would suggest calling in a Plumber to change it, as most states require a licensed plumber to execute this type of job, and many cities require permits for this to be done too.
Posted on Nov 03, 2010
SOURCE: I have a Moen L82691
You could try, but most likely its the hoses that are reversed. try that first i'll bet you it'll solve the problem.
Posted on Feb 07, 2011
  • 12 Answers
SOURCE: Bought a hot water heater made by whirlpool for 2
The down tube in the tank has fallen off or the hot and cold lines are reversed at the tank. I'm going to assume it is gas , if its electric you need to test the heating elements for continuity and temp settings. as well as the down tube in the top of the tank that sends the cold water feed to the bottom of the tank..
Posted on Mar 13, 2011
  • 961 Answers
SOURCE: Had the Moen L82691 installed
I think Moen is one of the easiest to work on and most trouble free there is. The only problems I have ever encouneterd with them is the mixing valve.This is the parts breakdown:
http://www.moen.com/shared/docs/exploded-parts-views/l82691pt.pdf
and a video
http://www.youtube.com/watch?v=J-SNBNijfQc
Of course you handle would have the set screw that holds it on. I would go to who ever you got the valve from and see if they will give you a new valve or, the video states Moen may provide a new one free. It's also possible, being a new install, that you may have had junk in your water lines that have now plugged the cold side of the valve. If you have some help, you may want to have someone taht can turn water off and on(slowly), cold first, and see waht kind of flow you have with valve out. Check for trash in the line and the valve first.
Posted on May 29, 2011
We have a moen 7594E. Lower water pressure than old standard Moen.
The pull out spout/spray has backflow preventers built into the hot and cold supply lines coming from the body of the faucet. The backflows have a tendency to lower the flow rate because of the additional restriction they cause.
Mar 07, 2017 | Moen Plumbing
Had new water heater installed. Ever since, there is very little water flow from both hot and cold faucets of both (dual) sinks in 2nd floor bathroom. Faucets are Moen 9000 M-PACT type. Could air be t
check the aerators on the faucets. i know after i change a hot water tank there is always some crud that comes through the lines and gets stuck in the aerators, they are the part that holds the screens in place on the spouts.
Aug 14, 2012 | Moen Plumbing
No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
Soak the dirty cartridge in vinegar for four hours and replace.
If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
Moen balancing spool
Moens balancing spool moves back and forth inside the cylinder to regulate flow of water to keep you from getting scalded. If it is not working properly you can get to much of hot or cold water coming out of the spout....or low to no water coming out.
Dec 02, 2009 | Moen Monticello Single-Handle Kitchen...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Water pressure became slow after less than 6 months of a new Moen Kitchen. Faucet some calcium build. Pressure is the same with both hot and cold running. Makes me think it is the faucet.
It is probably a clogged airator. If the faucet is the type where the spout is attatched to a hose there may be a screen where the hose attaches to the spout. with the spout off check the flow through the hose. If the flow at the hose is good then the problem is in the spout. Most of the time it is in the spout. you can replace just the spout if you cannot find a screen or airator to clean.
Jun 16, 2009 | Moen 7786SL Monticello Two-Handle High Arc...
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Water kitchen sink
I would check the strainers on the intake and the faucet spout. It is possible that sediment has built up and now is impacting thermostatic flow from the faucet... if one side is clogged its hard for the faucet to balance... try the stainer on the spout and any other strainers that may be on the supply hoses, valves, intake, etc...
Nov 23, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
677 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
