Question about Alpine MRP-M450 Car Audio Amplifier
Amp not working
I just hooked up my stereo and my amp is not working. The light doesnt come on and my sub doesn't work. There is power going to the amp i checked it with a volt meter its getting 12volts the fuses are fine and i changed them as a precaution and still nothing. I know this is a very general question but any help would be great thanks
    Genius:
  • 1,074 Answers
My friend your amp could be getting power that does not mean that it is working.the power only goes to certain point but because your regulator or other related component is defected your amp power supply will not work until the defect is corrected.take it to a tech and have your set repaired.good luck.
Posted on Jun 11, 2007
The car had existing cables in it and i tried hooking up the amp to a sub i know works. The amp doesn't light up or anything and the sub doesnt put sound. What's wrong?
Those existing cables are suspect. Start by getting power to your amp, then connect other wires, regardless of color code, to the sub. Beware of wires that look good but really are shorted somewhere. You may have to label each wire as you go along to identify its real function. You may even have to run some new wires to replace existing ones.
Sep 05, 2015 | Kenwood KAC-5204 350 Watt Max Power Stereo...
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
HAVE KIKCER L7 WHEN HOOKED UP TO AMP IT DOESNT DO ANYTHING HOW COME
lets do some diagnosis.. if it's possible, try hooking another known good sub up to the amp and see if that works. if it doesnt, it's an issue with your amp. if it does work though, it's an issue with your sub. or the wiring. if it's a dual voice coil sub, make sure you've got both positives hooked up to positive from the amp, and both negatives hooked up to negative from the amp. if you've accidently got positive from the amp going to positive of one voice coil then to the negative of the other, and the negative from the amp going to the negative of one voice coil then to the positive of the other, the voice coils will be pushing against eachother cancelling eachother's movements out. and this will fry the sub. OR the sub is already fried.
Feb 16, 2010 | Sony XM-2150GSX Car Audio Amplifier
Kenwoodxw1000f shut off after 10 sec
the problem sounds like your new sub is drawing to much power and your amp can not handle it. bridging the amp is a good way to get the full power out of your amp. But it isnt always suggested, my solution is to get a bigger amp. I install stereo systems for a living, and i tell my customers that it is smart to get an amp about 100 more watts then the rms rating of your subwoofer.
Feb 13, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
Sony xplode 1000w amp has green light puts out no power to subs
may haveto turn sub on through the stereo itself if rca cables are good.
Jan 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Infinity ps-10 powers up but no boom
Try hooking up a different signal input to your powered sub, another stereo or even a dvd players audio output to the sub will work for a test. Just make sure the subs gain is down before starting. If it still not producing sound, the subwoofers amplifier is bad. I hope this helps.
Oct 10, 2008 | Infinity PS-10 Subwoofer
Amp light is on but doesn't put anything out to my subs
if you are sure its the amp. the problem is internal. but if your not sure, try a different stereo or source of sound to the inputs of the amp. if there is still no sound than it is the amplifier and it could be a number of things.
Jan 07, 2008 | Alpine MRP-M450 Car Audio Amplifier
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Alpine MRP-M450 Car Audio Amplifier Logo
119 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
