When the page comes out after its printed how do I close they tray that it comes out on
  • 7,627 Answers
Very carefully! You didn't mention the printer make, model?
Posted on Dec 11, 2012
  • 942 Answers
SOURCE: The printer keeps printing the same page then come
Hi..
I think your there is a pending command to print, even if you have turned your printer on and off, it will print already because the pending printed papers in your computer is automatically printed, you need to check the printer status in your computer. just click start then all programs, then click printers and fax, now you can see now the printer icon just double click that, if you can see a pending printed, just right click and cancel, if you can not see the pending you printed document, you need to restart your computer so that all the pending command will turn out.
Good luck
Regards
PCmania
Posted on Jul 09, 2009
  • 5603 Answers
SOURCE: Printer error shows paper jam at paper tray and
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Posted on Dec 16, 2009
yooperbud
  • 8637 Answers
SOURCE: Page prints half page then jams
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Posted on Jan 07, 2009
SOURCE: my dell 1320c only prints first3 pages of a pdf
I had this problem with open office text files - the solution was to change the Page format (go to Format>Page) and set the page format to A4.
Posted on Jan 27, 2010
reyjoshua07
  • 1157 Answers
SOURCE: I have a Phaser 6250.
Hi jewaddick,
If your printer wont print from the bottom tray, it is often caused by a broken switch. Please check to see if the switch in the printer is not broken. Just take the tray out and look inside, you will see a switch assembly that corresponds to the printer tray setting. Also, please look at the paper sensor and see if it swings properly. If you will need to get a part, 116134300 1 SWITCH; PAPER SIZE ASSEMBLY. Here are additional troubleshooting that you may apply on this concern.
1. Unplug the Phaser 6250 usb and power cable. Wait for 30 seconds and plug both cables back in. Press the devices power button and try to print again to see if power cycling resolved the problem.
2. Try to uninstall and reinstall the driver if there is still a problem.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 23, 2011
Flashing C button
E then 3 then 0 means that it cannot determine the page size of the document to be printed.
E then 0 then 3 means there is either a jam in the output tray or the door to the output tray is closed. This is the tray where the paper comes out after printing. Try closing and opening the tray. A sensor could be stuck.
Here is the link to the manual. http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp495#BrochuresAndManuals
Nov 25, 2013 | Canon PIXMA MP495 InkJet Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Feeder won't work~~
Hello Sir; I believe just replace paper pick up roller feed roller and stop roller, the problem will be gone!
Jan 27, 2009 | Sharp AL-1551CS Copier
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
Xerox 8560MFP won't print first page from one tray and rest from another
Microsoft word overides the print driver for page choice. Choose from within word File | Page Setup | Paper.
Tray one on this printer is the manual feed tray. tray 2 is the first drawer.
Ensure the printer driver is set up for the additional trays
Jul 02, 2008 | Xerox Phaser 8560MFP Laser Printer
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
CD printing
there is a small,square button near the right,front corner. think of it as the button for the refrigerator light. It must be depressed by the closed top or maybe something to wedge it down. Duh
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
11 people viewed this question
k24674
