Question about KitchenAid KV25G0X Stand Mixer
Kitchenaid 450 watt model rkv25g0x it has only been used. 3 or 4 times does not turn on
Does not run I have checked the outlet ans I have 120 volts.
4 Suggested Answers
  • 22 Answers
SOURCE: Kitchenaid pro stand mixer will not turn on
How comfortable are you with electrical parts? With the mixer UNPLUGGED and the switch ON measure resistance between the (flat) plug pins. If it's infinite (no meter movement) which is to be expected, there is an open circuit. The switch could be open or the wire to the switch could be disconnected (improbable) or the motor could be burned out and open (not very probable).
Maybe you could take the switch to a shop and have it tested.
This is not really a solution, just step 1.
Posted on Mar 14, 2009
hslincoln
  • 235 Answers
SOURCE: kitchenaid 625 watt 6 quart mixer. Was using it
HAMILTONCOOL - It appears that your mixer had a mechanical failure in the transmission box or planetary gear assembly of your mixer failure - one of the main gears has failed, hence the loss of power to the agitator. You didn't mention any associated noise prior to the loss of power to your agitator, but I'm assuming there was just a little more noise than usual, prior to failure.
The inspection and troubleshooting of the transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, and then select Parts List file. You can check the page titled 'Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. It can be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc. Good hunting... I hope this helps - Howard, Burke, VA
Posted on Nov 19, 2009
  • 506 Answers
SOURCE: Hi, we bought our Kitchen Aid
There are a couple of problems here. First your country employs the 240 Volt mains supply. You can tackle this by buying a decent sized VARIAC. This is an auto transformer that will allow you to adjust the AC voltage to what you need. The other problem is that the motor in your mixer was designed to run at the US 60Hz mains frequency whereas Australia is 50Hz. It may end up running too slow regardless of whether you use a VARIAC. I hope this helps. Best Regards.
Dave
Posted on Jun 12, 2011
What size fuse is needed for a 600b mixer?
I am guessing you have an older Peavey mixer amp. I believe these mostly used 8 amp fuses although older earlier ones may have used different. It should say on the back at the fuse holder. You can get these at Radio Shack, at better hardware store in either auto electrical or electric sections or on line.
Oct 05, 2014 | Food Mixers
KitchenAid mixer,model # KG25H0XMC5 will not turn on.
Check different outlet. Make sure the outlet isn't at fault.
Aug 01, 2014 | KitchenAid New Professional 5.5 QT...
Kitchenaid mixer. I am moving to a 220 v country. I have been told changing out the control board and speed circuit will enable me to use my mixer there ? Is that true?
Kitchenaid does not recommend using a US model mixer overseas since the frequency is different. Here in the States we use 120 Volts 60 Hertz, it Europe they use 240 Volts 50 Hertz so even if you were to feed it the correct voltage, the frequency would still be lower and the mixer would run slower and hotter causing shortened life of overheating.
Apr 05, 2014 | KitchenAid K45SS Classic Stand Mixer
My KSM150PS stopped working!! HELP!!
Yikes!!!!
Can you tell us what you were making last time you used the machine? Do you do pizza and other doughs a lot. The KSM150 is a 325 watt mixer with lots of power so;
1 first lets go back to the outlet and try anything that can show fast results like a hair dryer to test the outlet.2 The cord from the mixer, do you unplug it by pulling on ti? Or do you use the plug itself when unplugging. Do you have and know how to use a volt meter. If yes to both
3 Remove the rear cover and you will see a black and copper plate with a whole bunch of connectors on it. the left two bottom black and white terminals are the power for the mixer, turn the mixer on and test the terminals to make sure the machine is getting power, if not replace the power cord. You will have to open the machine and take it apart somewhat to replace the cord.
4 it could be the speed control plate itself (Most likely) there are three screws on the plate in an upside down triangle, turn the one on the bottom left a little bit while the mixer is on if it is the adjusting screws it should start again with less than a half turn.
5 Look at all the terminals to the speed control switch and make sure that they are connected if any one of them has come off then the machine won't work.
There can be other problems but this fix is the most common. Let us know if this does not work and we can go into it a little more in depth.
If you leave the machine on for a minute or more does it start to smell (burnt smell or hot electric) If you have a warranty (still within the first year of purchase ) get in touch with Kitchenaid they will send a new mixer with out question. If you are out of warranty then we can fix it, one step at a time, or you could take it to an authorized service center, if you live close by to one. Let us know.
Jan 19, 2013 | KitchenAid KSM150PS Artisan Series Stand...
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
Hi .. am in a country that has 220V power outlets. What do I need to use my kitchen ais that has 120V, 60hz and a maximum of 330 Watts requirements?
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 04, 2011 | KitchenAid Artisan KSM150PSSM Stand Mixer
My Kitchen Aid Pro5 squeals when it's running. I may have overheated it when mixing bread dough. It seems to be running okay. It just makes a very high-pitched noise now. What can I do to fix this?
Get a Copy of the Repair Part List of your model from Kitchenaid.com.
Most likely it is the Worm Gear (17) grinding at low speed the Worm Gear Follower.(19)
You don't have to replace it now, but it is best to open the Transmission Housing and
inspect all the gears conditions. Clear all the grease to expose them. The Bevel
Gear (21) sits right on top of the Worm Gear Follower. (See Repair Part List)
If its teeth look sharp and all metal shiny, then that is the source of your noises.
Eventually, all the teeth will be chewed away and the planetary assembly will stop turning.
Jul 01, 2011 | KitchenAid 450 Watts KM25G0XWH Stand Mixer
Kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Sep 24, 2008 | Food Mixers
KitchenAid KV25G0X Stand Mixer Logo
74 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
