Question about MXR M151 Double Shot Distortion Pedal
My MXR doubleshot will not switch into distortion mode
The pedal lights up when it is plugged in, and will play clean. Once the overdrive button is hit, no sound is produced, not even feedback. Both distortion channels are experiencing this issue. If this is not something I can fix myself, who would I be able to contact concerning the repairs? I have had no luck looking for Dunlop's tech services number or mailing address.
4 Suggested Answers
  • 41 Answers
SOURCE: I have the MXR EVH
The fact that it happens with 2 different units may point to something in common. You just first eleminate the cables as a possibility by swapping. Also, most pedal problems can be traced to a battery issue, so make sure it is a good one. Make sure you are using mono, not stereo cables.
The footswitch could be faulty, try holding it in different ways to see if it makes contact.
Posted on Feb 28, 2011
  • 5603 Answers
SOURCE: I just bought an MXR
The battery is being shorted by something. It is impossible for me to guess what without looking at it. If the pedal is brand new, take it back for warranty repair/replacement. If you bought it from somebody, you bought THEIR problem... they likely knew about it. If this is the case, look for a pinched wire from the battery lead... make sure it is not backward. If you can't see anything and cannot get a refund, open the pedal. Look for a problem where the 9 volt adapter plugss in. Broken jack, etc. Look for evidence that somebody has taampered with the insides. Of course look for foreign debris.
Posted on May 06, 2011
  • 5603 Answers
SOURCE: I just got an MXR
Most common problem is the in and out cables are backward to cause this.
Posted on Jul 06, 2011
MXR phase 90 swtiches on but I have no phasing
I would check the difference in sound between using an AC adapter and a battery. These things lose the effect when the batteries get low.
Mar 28, 2014 | MXR Phase 90 Pedal
Do you run a compressor in the effects loop?
Yes. I run all my modulation pedals into the compressor, then into the MXR Ten Band EQ, then into the effects loop. But it also works in the front of the amp as well to tighten up your distortion. Try it both ways and find the sound you like best.
Oct 13, 2013 | Pedal Mks Patch Pad Stereo Routing Module...
When i plug an MXR micro amp (volume boost) in front of the supersonic, it works on the clean channel but does not affect the burn channel, Why? By the way, when plug in to the effect loop it does work...
DO NOT USE a guitar pedal in effects loop as it has the WRONG signal levels.
Also, when you boost the gain preceeding a distortion setting in an amp, the amp will just limit out and it will appear that the effects in the amp aren't working... but what is happening is you wind up with too much input signal and the "flat topping" distortion occurs right at the inout of the amp so no further can occur when you select a distortion in the amp.
Jun 22, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
MY MXR STEREO CHORUS LED LIGHT START TO FADE AFTER CONNECT WITH DC BRICK! DOES THIS MEAN MY PEDAL WILL HAVING ANY DEFECT?
I don't know what you mean by "DC Brick"...
The MXR Stereo Chorus unit requires a special 18 Volt power adapter. The common 9 volt pedal power adapters will NOT work with this device. If you have batteries in the unit, when you plug in an incorrect adapter, the unit disconnects from the batteries and the caps discharge so the light will fade.
You will need to use: ECB-004 18-volt AC Adapter Best to use the manufacture's exact device for this one.
Jan 12, 2011 | MXR Stereo Chorus Pedal Guitar
I have a crate fxt 120. I 'll be playing in the #2 overdrive channel and it will automatically fail and go to a clean sound. Although it is not entirely clean. It sounds like 2 sounds combined. A loud...
A possible problem MIGHT be marginal switch contacts on the external foot controller cable. If you are not using the foot pedal, these contacts must maintain contact to keep the same channel selected.
Sep 15, 2010 | Crate Music
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
MXR Phase 90 doesn't phase only clean signal. The oscillator is working and I have changed the BJT's.
sounds like a switch contact problem, try some surgical alcohol. (for the MXR not for you!!!)
Dec 31, 2009 | MXR Phase 90 Pedal
I need the operation manual for a Danville tec80G guitar amplifier. I also need to find out where I can get a footswitch for this amp. I would like to be able to incorporate some sort of distortion...
Well,its a real obscure amp.No company website from what I can find.
Here is a review of the amp though on a good tab forum:
http://www.ultimate-guitar.com/reviews/guitar_amplifiers/danville/tec80g/index.html
As for the footswitch dist.pedal,you have a few options.Look on the back of the amp and see if there is A)an effects loop.This may say "return" and "send" and you can hookup a pedal through that to bypass the input jack.Then just plug in normally to the front of the amp.Also check to see if there is a 1/4 input on the back that may say "footswitch".If so,fender makes a button footswitch that comes with most of their middle of the road combo's.This plugs in just like a guitar cable and will switch your channels.
If you need a recomendation on a distortion pedal go with MXR.Its a little morre expensive(by $10.00 maybe),but its the best bang your gonna get out of a pedal.
Sep 21, 2009 | Music
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
MXR M151 Double Shot Distortion Pedal Logo
Top MXR Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a MXR Music Expert? Answer questions, earn points and help others
