Question about Warmrails & Satin Nickel Towel Warmer & Drying Rack
Need an on/off switch for Warmrails C-3382
Have a wall mounted warmer bought in '06. Worked great until the power switch shorted out. Would like to replace the switch.
2 Suggested Answers
  • 10865 Answers
SOURCE: New Warmrails Towel Warmer Stopped heating
call the company directly at 877-927-6724. Explain the problem and they will assist you or replace your unit.
Posted on Feb 19, 2009
Where can I buy a new illuminated on/off switch?
An electronics shop or auto parts store should have one but it might not be an exact fit. If the switch is stuck in the ON position you could just leave it and put a new switch on the line cord.
Mar 13, 2011 | Warmrails & Chrome Towel Warmer & Drying...
I have a Liftmaster Model 2500 opener. It is about seven years old, and worked great until recently. It has stopped working, including no lights at the Multi-function door control. If I unplug the...
THIS IS PROBABLY CAUSED BY A SHORTED WIRE.
OR A BAD WALL CONTROL.
DISCONNECT WALL CONTROL & TEST.
IF STILL NO RESULT DISCONNECT WALL CONTROL WIRES AT THE POWERHEAD & TEST AGAIN.
REPLACE WIRE OR WALL CONTROL.
HOPE THIS HELPS
Nov 15, 2010 | liftmaster Chamberlain Garage Door Opener...
No screws to mount AKAI LCT3701AD LCD TV.
Hi i bought mine at home depot for a few dollars they were very helpfull there and they worked great...
Feb 03, 2010 | Akai LCT3701AD 37 in. LCD Television
Power will not stay on
HI, make sure there isn't a short in the actual outlet wall socket. if the outlet wall socket is in good condition, this will confirm power board failuer.
You will need to replace the power supply board in this unit in this case.
Jun 13, 2009 | Reebok Vista Treadmill - RBTL13305
Jan 10, 2009 | Warmrails & Satin Nickel Towel Warmer &...
Sony KV-35v35 no power
Bad Picture tube,and Flyback transfomer, shorted hori output.
Dec 12, 2008 | Sony KV-35V35 TV
Lcd television trips circuit breaker when plugged in to wall outlet. Problem started yesterday after wall mounting the unit.. Removed wall mount and it still happens (worked fine before wall mounting...
I would check 2 things. If the TV trips another breaker in the house of the same rating, you probably have a short in your TV and will need to have it serviced.(You didn't drop it did you? :-) ) The short may also occur by too much stress on the power cord where it enters the TV, common to need to cram the cord into small spaces when wall mounting. If the TV only trips that particular breaker, I would try replacing the breaker. Replacing the breaker costs very little and will only take you a few minutes. You can buy a replacement breaker at most hardware stores. Just make sure to disconnect the main supply first! Also, make sure the breaker is rated correctly, using a higher amperage breaker will increase your chances of starting a fire.
May 05, 2008 | Televison & Video
Panasonic Quintrex 32" 100Hz CRT
Use an uninterrupted power supply, UPS.
Feb 21, 2008 | Panasonic CT-32SL15 32" TV
Panama 5 12444T
try to replaced the dimer switch with new one.
Jan 19, 2008 | Casablanca Fan 74U9D Four SeasonsĀ® III...
Warmrails & Satin Nickel Towel Warmer & Drying Rack  Logo
54 people viewed this question
Top Warmrails Home Experts
john h
Tom Chichester
Are you a Warmrails Home Expert? Answer questions, earn points and help others
