Question about Drive ION iTT03x Turntable
I have an Acer computer with Vista window. my C drive is 30 GB although it doesnt have to much data but it showes full.
  • 81 Answers
Well my friend the reason could be the low space on the hard disk drive & at the same time also try to defragment the C drive of the system & then check the status... Also let me know in total how much of physical storage space do you have on the computer.
Posted on Jan 13, 2009
C drive says there is almost no space
I assume that you're running a spyware/adware program weekly and that no one using this laptop is downloading movies, or large amounts of audio files as either can fill the hard drive fairly quickly. Also, although it is usually given a different drive letter, you may be viewing the restore partition Acer uses if the computer needed to be reset to original factory settings.
Jan 08, 2014 | Acer Aspire 4250 4251 4252 4253 4333 4339...
2GB Cruzer Micro USB Flash Drive (SDCZ62048A10) Hard Drive: i just bought a 16 gb sandisk flash drive. i took...
go to my computer, plug the drive in, right click the flash drive icon on my computer and click format.
May 18, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hanging of laptop, when i open twoor more programs
Well, you need more RAM. 1 GB is not enough for Vista Ultimate. Contact Dell to upgrade and add a 2 GB memory module for a total of 3 GB. Apparently, you have 30 GB disk full with the Vista OS and software programs. At some point, I'd like to see you extend your partition for your 160 GB drive so that "C" is much larger than 40 GB. You'll need one-one assistance via FixYa.
Jun 12, 2009 | Microsoft Windows Vista Ultimate Edition
Have tried a solution but there's still a problem
look first make habit of saving ur downloads to Drive D ok never save ur download s on drive Acer : C secondly let me tell u windows Vista is a bulky OS and it needs much space on hard drive thats why atleast 120 Gb is recommended for Vista it seems like u have an 80 gb hard drive Vista will work but it will take much of ur drive space as my Vista installation is around 39 GB now i dont know but it grows his size day by day thats why some ppl with less system resources go back to XP , u can free up more disk space by doing following:
go to http://www.ccleaner.com download ans install it run the cleaner and look for temp files that may be lying and occupying disk space.
2. Go to My Computer Right click on Acer C take properties click button Disk cleanup select files from all users let it scan ur hard drive and then it will present u with some temp files , hibernation files and thumbnail files and error reporting files check the boxes and perform the cleanup select all of them u will get some space press OK it will cleanup and delete these files and u will see some space freed up, in more options in the same windows u can also uninstall some progrmas on ur C drive which u installed and u no longerr want now u can un install them as well after that come out of it
3. Now go to My computer right click and take properties of Acer C now go to Tools Tab and select Defragment Now and select C drive and defrag ur drive this will take time after this correct free space will be visible to u after all cleaning steps
if u get enuff space u wanted then it is ok otherwise u can also take some space from the D drive and can merge into C drive if u want i can help u in that but i prefer changing ur hard drive as it is too small for a system like Vista , XP will give u no trouble on that drive
pls let me know and do rate me if i fixya problem
Feb 25, 2009 | Acer Aspire 9410-4317 Notebook
My Acer C: drive is full but Data D: drive is not.
Find a picture on the internet.
Right-Click the picture.
Choose "Save As"
A box will open like this one:
click on My Computer and point it to where you want the file to be saved on the C: drive (the one with all the space).
It will remember the path so you only have to do this once.
That's it.
If you have any more questions, feel free to ask. Please don't forget to rate my solution.
Thanks!
Feb 24, 2009 | Acer Aspire 9410-4317 Notebook
Displaying write protected while loading and deleting files
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Dec 11, 2008 | Transcend (589307) Media
Drive ION iTT03x Turntable Logo
41 people viewed this question
Top Drive Audio Players & Recorders Experts
 Grubhead
Grubhead
richie46
Darrell
Are you a Drive Audio Player and Recorder Expert? Answer questions, earn points and help others
