Question about SharpVision XV-Z9000U Multimedia Projector
Projector shut down
When i start up the projector it appears to be warming up but shuts down about 10 seconds after i press start.
  • Anonymous Feb 09, 2009
    I have the same problem.  The bulb light and the power light come on solid red and there is no way to turn the projector off.  When I unplug the power cord and then plug it back in the projector automatically tries to start up but then fails again after about 10 sec.  I hear a whirring noise that sounds similar to a cd rom drive that speeds up and slows down.  I looked at the bulb and can see nothing wrong with it. I also noticed that the bulb does come on but only for a second or two.
  • jasbo
    jasbo May 11, 2010
    what model?
SOURCE: Sharp Notevision 6 XG-NV6xU
reset the lamp hours on your projector
Posted on Dec 27, 2007
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
SOURCE: Sanyo PLC-XT16
The problem is faulty capacitor on one of the control pcb's . needs to go to a technician for repair
Posted on Jul 04, 2008
projdoc
  • 2237 Answers
SOURCE: projector shut down after replacing the bulb and wont turn on now
are any of the leds on the top of the projector lit? if so, which ones? red or green?
Posted on Aug 06, 2009
  • 8909 Answers
SOURCE: Mitsubishi SL2u projector: Projector was recently
I suspect the lamp cooling fan. Check the fan for debris or damage. If it were the sensor, it would be showing fault mode and not even start up. Hope that helps.
Posted on Nov 16, 2010
Shut down after 30 seconds
Many projectors shut down if they cannot find anything attached to them.
Make sure you have a computer attached and sending an image out to it before you hit the projector reset button again.
It's a bit like the chicken and the egg since some laptops won't send an image out the cable unless it senses a projector, and the projector shuts down if it does not detect an incoming signal fast enough.
Apr 23, 2014 | Acer PD528W Bulb
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
Sanyo PLC XU105 Will shut down in 10 to 15 seconds
YOU HAVE A BAD LAMP OR THE LAMP DRIVER BOARD BAD
Aug 24, 2009 | Televison & Video
Shutdown & error led blinking 2 times
Shut off your projector by swith on the back near the AV inputs, leave it off for about five minutes. Then switch it back on, manually press the power button, let it start for about 5-10 seconds then continue to hold power button until picture appears. It worked for me, good luck to all.
Mar 24, 2009 | NEC HT1100 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Jul 28, 2007 | Sharp Notevision XG-NV6XU Multimedia...
SharpVision XV-Z9000U Multimedia Projector Logo
293 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
