Missing accessory ac charger dc charging led flashlight
  • 7,627 Answers
Can you rephrase that question? Maybe with some punctuation marks?
Posted on Dec 11, 2012
Damilare
  • 358 Answers
SOURCE: dell latitude 400 charging problem
Your english is actually above average!
For you to get the best solution to this problem, I'll suggest that you should just try and get a friend, or a technician that has a charger of the same type, i.e a Dell Laptop Charger, to test it with. Now, if it still doesnt work, then you can try and swap the Battery with a working one also. All these are just to clarify things for you and to teach you the easiest way of troubleshooting it yourself.
Then If the new charger charges it, it means you just have to get a new charger, and if the Battery swapping is the one that works, then you might have to get a new battery too.
At the same time also try this quick solution :
Remove the battery from the back of your laptop, and power the laptop without the battery inside. If it works this way, then just try and get a new battery instead.
Hope this helps you out!
Goodluck
Posted on Jul 13, 2009
  • 1121 Answers
SOURCE: my t1200 wont charge and also when it was charging
u have a battery with shortcircuit,
1st u need to test the charger without battery inside, for temp. and computer functions
2nd u need a battery spare, and test the same
if continues, send for repair shop for test and checkout
Posted on Nov 28, 2009
  • 33 Answers
SOURCE: Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Posted on Jan 27, 2010
  • 2567 Answers
SOURCE: Hellow Dear, My acer aspire 4935
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 15, 2010
  • 7 Answers
SOURCE: My Laptop won't power up
try plugging it to another same brand laptop. if the result is the same that means ur power adapter is faulty, if it's ok with other laptop then its ur laptop's power connector & motherboard is faulty
Posted on Aug 09, 2012
When connected to AC mains and switched on there was no sign of glowing led displaying charger is "ON"
Use multimeter to check output of AC Adapter. If no DC output at required voltage you should replace adapter; available after market units sell for $10 to $15 delivered.
Jan 03, 2014 | Compaq 239427-001 Laptop AC Adapter...
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
My vector vec157 will not charge on 120 volt. It works on 12 volt
If you light is charging when you use the 12v automotive charger but not when you use your AC power transformer, my thought is that you might have a problem with your AC charger, not with the light itself. I have AC/DC transformers from the 1970s that still work fine, but I have had numerous modern AC/DC transformers burn out on me in recent years.
One easy test is to use a multimeter to measure the output voltage of your wall charger. Place one test lead on each of the charging terminals (i.e., one inside the barrel and one outside the barrel, if you have a standard coaxial charging port) and check the DC reading. If it's zero--or anything less than 12 volts, actually--the charger isn't working correctly. The problem may be a torn or cut wire or something actually inside the transformer.
Replacement chargers can be found at Radio Shack and other stores. You may also be able to score a cheap replacement at a "dollar plus" store or even at a second-hand shop. Make sure that the terminal polarity is correct on your replacement charger or else you'll fry the batteries in your light.
Sep 08, 2011 | Vector 20 Million Power Series Spotlight
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
Jan 28, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
Ultrastinger Rechargeable Flashlight with DC Car Charger/Holder: charger lite will not come on! there is power to c...
Most likely a short in the charger wiring, try to find someone with another light like yours to confirm, if so you will need to buy a new charger. it coild also be a short in the flashlight charging port too, you will need to confirm with another charger.
May 18, 2010 | Streamlight Ultrastinger Rechargeable...
Can't find chargers for my 1M cp vector vec127by spot. What are the charge rates for a 120v ac charger and the dc car charger?
10-12 hours for 120v AC charger, I do not recommend using a DC car charger to charge the battery. You can purchase a replacement AC charger from Black and Decker, they service Vector products. here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jan 29, 2010 | Camping, Backpacking & Hiking
Need pin connections to lg vx-4500 for DC charger
The phone side connection should look like this image
Nov 18, 2008 | Cell Phones
Charger
The light can come in a box with just the light alone (light with battery), single ac(light with ac cord and 1 charger), single dc(light with dc volt cigarette outlet and 1 charger), double (light, 1 ac, 1 dc cord, 2 chargers) pb charger...and so on. The sticker on the box that contains the UPC code should have the listed detail on what the box should contain. Still confused check out the website www.streamlight.com search the light you're looking for and check out the product part number list. Hope that helps ;)
Jul 21, 2008 | Stinger Streamlight 75000
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
