Question about Riccar 8955 Upright Vacuum
Riccar 8955 carpet/floor switch won't stay on carpet mode keeps moving to floor mode
5 Suggested Answers
  • 25 Answers
SOURCE: riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
Posted on Mar 03, 2009
Vac Belts
  • 701 Answers
SOURCE: no suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Posted on Dec 30, 2009
SOURCE: hello
buy a new one save your safe the time.
Posted on Feb 10, 2010
  • 694 Answers
SOURCE: absolutely no power. No light or anything. Is
There's a small white button on the back of the machine near the left wheel. Use a paper clip or similar item to push that in.
Posted on Aug 22, 2010
Why does the riccar vacuum reset button not depress?
In my experience the Riccar requires reset when it has ingested something that jams the roller such as the fringe of an Oriental carpet. Be sure to clear any such obstruction, then I use a ball point pen to press the button. It does not move very far to accomplish a reset.
Jun 18, 2014 | Riccar 8955 Upright Vacuum
Can't adjust from floor setting to carpet setting
The carpet / floor selector moves a rod which adjusts the clutch, Your model is over 10 years old, it may need a new belt, clutch rubber pad or just need adjusted. If you don't know how to perform these services take your vacuum to your local Riccar dealer for service. It's the least expensive way to keep it working properly for many years.
Apr 07, 2014 | Riccar 8850 Vacuum
Riccar 8955 power cord schematic
The black wire goes to the switch, the white cord goes to the white wire in the vacuum.
Feb 14, 2014 | Riccar 8955 Upright Vacuum
After changing the bag on my riccar it is very hard to push'
after putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Apr 22, 2013 | Riccar 8955 Upright Vacuum
The bare floor/carpet switch moves on it's own from bare floor to carpet all the time.
I'm sorry to hear you're having difficulties with your DC07. When you have your brush control set to 'Carpets', the brushbar should run when the cleaner is reclined into the vacuuming position, and shut off when you stand the cleaner upright. When you have the brush control set to 'Hard floors', it should remain in the off position until you change it manually back to 'Carpets'.
If it won't stay in the 'Hard floors' position during use, it's probably best if you get in touch with us directly so we can determine if there's a fault, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes will not spin when in the lock down position. I adjusted the arm internally and it does not seem to apply enough pressure to have it fully lock down. Can the mechanisms wear out.
This unit has a rubber "clutch" piece to engage the brush which must be replaced occasionally. See if you can move the brush with your fingers while holding the belt to prevent it from turning - be sure the switch is set to carpet, and the motor is off. If you can turn it, the clutch needs replacement.
Jan 20, 2011 | Riccar 8955 Upright Vacuum
Our Riccar SupraLite Upright Vac used to glide across the floor so easily, but now we have to push it pretty hard. This just recently started. What can be wrong?
Suggest you check the wheels to see if they are moving freely. Also check the beater brush to see that it is moving freely. Be sure the belt has not broken. If it has, replace with a new one. Also take the time to clean the beater brush of any debris and spray a little WD40 on both ends of the beater brush axle.
Sep 12, 2010 | Riccar 8955 Upright Vacuum
8955 Upright Vacuum: How to change belt?...
Be sure to unplug your vacuum from the electrical outlet before proceeding!
-Turn your vacuum upside down so that the handle is resting on the floor and nozzle portion is resting on a work bench.
-Remove the 2 phillips screws from the metal bottom plate and set the bottom plate aside.
-Look at the right side of the brush roll. You will see a bent metal rod that attaches to the brush roll end cap. This is the clutch rod that allows your brush roll to spin or not depending on the position of the carpet/floor switch on the top of the nozzle. Pull this rod out of the brush roll clutch only. Leave the switch end of the rod where it is and just let the rod rest there.
-Pull the brush roll and old belt out and dispose of the old belt.
To install a new belt; put the new belt on the motor shaft first, next put the other end of the belt over the end of the brush roll and stretch belt and brush roll back in to place. Notice that on the brush roll end cap opposite of where the clutch rod goes, there is a metal piece with a slot cut into it. Be sure that this slot mates with the plastic stop in the nozzle so that the end cap cannot move.
Snap the clutch rod back in place and rotate the brush roll by hand to make sure the belt is not pinched.
Replace the bottom plate.
May 18, 2010 | Riccar 8955 Upright Vacuum
Remove and replace belt
Hi There,
Here's a very helpful repair that I did exactly for your problem on how to replace the belt on your Riccar. Your model, the 8955 is more difficult then other models due to the rug/floor selector knob. No worries though, I explained this step by step with pictures.
Hopefully this helps you,
http://www.fixya.com/support/t4373126-replace_belt_in_8850_model
Chris Jones
GoVacuum.com
May 02, 2010 | Riccar 8955 Upright Vacuum
Riccar 8955 sweeper won't run...where is thermal protection switc
Nov 24, 2008 | Riccar 8955 Upright Vacuum
Riccar 8955 Upright Vacuum Logo
270 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
