Question about Motorola Mobility DCH3416 (160 GB) DTV Receiver Video Recorder
Dch3416 error message?
Hi, On the display there is a message that says "EAS" what does this mean? At first it wasn't working at all until i unplugged the DVR and then replugged it back in. It started to display channels again, however, the volume wouldn't work. I checked that both the DVR and TV were not on mute, but I'm thinking it has something to do with the "EAS" message across the screen? Please heLP?
Sharp ar-164 - Displays "h4"
this error means:
heat roller abnormally low temperature.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 25, 2012 | Sharp AR-164 Copier
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
In trying to install various versions of Adobe Reader on Windows XP SP3, I get the following error message: "Installation encountered errors; failed to initialize." I get this message on...
Yo! I will have to direct you to a website where you can download anything for your computer.i advice you download another one from here. please follow the link below..
www.download.com
Jul 27, 2011 | Computers & Internet
What does "ue'"mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 29, 2011 | Samsung Washing Machines
I just got att dsl service. I have four green lights on the modem and wireless is working. I can access wireless on my phone and laptop in the house. When I open IE, all I get is "cannot display...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online
All the best
Ben
Jun 03, 2011 | AT&T High Speed DSL Modem
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
Looking for the meaning of error code on the CED DUI or DU1 for a DCH3416
DUI is actually trying to display DVI on the box (the LED won't display the V and makes it a U). You typically see this error when your connected to your TV through an HDMI cable and the handshake for HDPC is lost. The box thinks your TV doesn't support it and wants you to change your connection. The error should go away once it finds that handshake. If you were using a different input on your TV, maybe a composite or something for a DVD, and then switch back it can get lost. If it doesn't clear right away try shutting everything off and turning it back on by turning on the TV first and then the box.
Jun 09, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Motorola Mobility DCH3416 (160 GB) DTV Receiver  Video Recorder Logo
99 people viewed this question
Top Motorola Mobility Televison & Video Experts
Are you a Motorola Mobility Televison and Video Expert? Answer questions, earn points and help others
