Question about Samsung Televison & Video
Will using a 7a 125v power cord hurt my television when its made for a 5a 125v cord?
My Samsung HC46C6300 LED flatscreen television's power cord is lost and am unable to find an exact replacement without spending considerable amounts of money. Will using a slightly different cord (the tv came with a 5a 125v cord but I have a 7a125v cord now) hurt the television in any way?
SOURCE: LG 20LS7D
It uses a regular power cord, the kind that you would use for a PC.
Posted on Dec 21, 2007
SOURCE: Sova Digital DS205-S32 Television power cord adaptor
I finally got the power supply fixed.It cost about $300,but the TV works know. Same Day TV in Norfolk VA
Posted on Jan 24, 2008
SOURCE: samsung s42sd-yd01 plasma television wont power up
i have also this problem 1 relay klikt than must klikt the second relay it do nothing
i see a few elco,s on the visibel boards who are dik the plastik is dik not the metal
to hot maybe
can this give the problems
somewone a solution for this tv ??
sorry for my bad englis
thanks
Posted on Aug 13, 2008
SOURCE: I purchased an AVEis 26
Cheap made in china ****. Hard to find anything decent in eletronics these days...stick to the best known brands. Avis doesnt even have a website for help or warranty issues.
Posted on Jul 08, 2010
SOURCE: Olevia power cord...
ebay is selling olevia power cords for $7.99
Posted on Aug 18, 2010
Power cord for Janome MC11000 sewing machine
You need to require parts from Janome, Contact them here
Jul 18, 2008 | kawasaki PVS1080
Big Screen RCA Tv Model #P60923BL or OM60923BL
bamones, it`s possible but not likely, remove AC cord from wall outlet, remove back from set and follow the AC cord where it goes into the set, fuse is right beside where the AC cord attatches to the board, if the glass is black you have a dead short in the power supply, if it`s open but not black then try replacing the fuse, amperage is marked on the silver metal end of the fuse, look for a number followed by the letter "A". Example;
5A 125V would be a five amp fuse rated at 125 volts, DO NOT replace with any other value, good luck, BMW Rider
Dec 19, 2007 | Televison & Video
Can you use a power cord from a Samsung 39 inch flat screen on a Samsung 65 inch flatscreen
yes, most tv's that i know of take two types of power cords, both of which are ok to mixmatch. As long as the new tv uses a molded u ground cable (3 holes on female end) or the smaller ones (2 round holes on female end) which most do it is perfectly safe to do so. As long as the tv did not have the box attached to cord ( regulates wattage) if that is the case you need one that supplies the EXACT wattage to the tv but i have yet to run into a tv that uses a power cord like that.
Feb 21, 2015 | Samsung Televison & Video
Apex ld3249 what ac. Power cord do I need 10a 125v or 7a 125v
Hello
The power in cords have no specification and it is not a critical component to any device. Just buy one power cord, whicn meets your need. Get it from a reputed electronic spare part selling shops at your town. Keep the present power cord in hand as a sample, when you go for new one. Most of the present power cords will meet your need.
http://www.dataentryjobs.us/67948.html
en.wikipedia.org/wiki/Power_cord
Feb 01, 2012 | Televison & Video
My samsung flatscreen series 5 has no power
Hi chic_currie,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply.
You may also replace the entire power supply board for your convenient.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free.
Hope I helped you.
Thanks for using fixya.
Jdvillanueva
Jun 10, 2011 | Samsung Televison & Video
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
87 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
