Question about Dell Inspiron 1525 Laptop Flamingo Pink
I want to install XP and vista - Dell Inspiron 1525 Laptop Flamingo Pink
    Genius:
  • 2,785 Answers
Plz install xp first then vista in another drive.
Posted on Jan 13, 2009
Gets error code 0x0000007B when I attempt to install XP on hp pavilion dv6-1245dx pre-installed with Vista
Nomally on a vista installed lap you will have reverse compatibility issues when you try to install xp cause vista is a newer editon than xp. So it would be advisible to use a virtual machine software to install xp inside vista.By doing this you can simultaneously run vista and xp at the same time.you can download free software line SUN VMWare.
Oct 10, 2009 | Computers & Internet
I hate Vista. I want XP.
Hai,
Yea that's true Vista sucks.....XP best!
If you want to install completely with XP then as usual procedure format the system with your Windows XP CD(C:/ drive only, with FAT32 or NTFS).
Aug 23, 2009 | Microsoft Windows XP Professional SP3 Full...
Windows xp installation problem
You might need to use the "Floppy" version of the Driver upon install (if you know what the chipsets are. Most likely it's Intel and you can slip stream the driver files into a new XP CD.
However if a partition is formated from Vista and you attempt to install XP over it without formatting it, crash is almost certain - XP and Vista have different versions of NTFS.
If you want both XP and Vista on the same machine, ALWAYS install the older one first! i.e. XP first. And create only 1 partition in XP where you intend to install on.
Then install Vista afterwards with Vista created partition.
May 23, 2009 | EliteGroup RC410L/800-M2 (V1.0)...
Installing xp
Once you have installed Vista which is a higher version than XP, it is not possible to install XP after having installed Vista. The best way around is to uninstall Vista, load XP first and the again install Vista on a diff. partition. Now it should be operable with the choice to switch to the OSat your convenience.....sodeep
Apr 04, 2009 | Computers & Internet
HOW TO INSTALL XP IN VISTA OS OF LAPTOP HP PAVILIION
Hi there.
The only way you can install XP on a Vista machine is to install "virtual XP" onto Vista using Virtual PC 2007.
Here is a site that will take you through the procedure step-by-step and gives links to download Virtual PC and install it onto the machine.
Please be aware that some drivers may not work whilst using XP when you have it installed.
http://lifehacker.com/software/windows/geek-to-live--run-windows-xp-inside-vista-with-virtual-pc-238071.php
Have fun, good luck and thanks for using FixYa!!
Mar 23, 2009 | HP Pavilion DV6700T Notebook
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Mar 16, 2009 | Microsoft Windows Vista Ultimate Edition
Video card not working with xp sp3
The drivers for XP and Vista are different. You will need to install the drivers for XP as well as Vista for dual boot operations. Make sure you install the XP driver in the XP partition and the Vista Driver in the Vista partition. This should solve the problem.
Dec 20, 2008 | Computers & Internet
Xp on a vista laptop
Hello
I regret to inform you that it is not possible to install XP in the HP or Compaq Notebooks which are shipped with the Vista Operating System. To install XP in your notebook, you need to disable SATA option from the BIOS . I am afraid that there is no SATA disable option the BIOS. Hence, it is not possible to install XP in the notebook.
I understand some of the softwares are not compatible with Vista operating system. But, if you insall Vista SP1 in your notebook. You can also use the software which were not compatible with Vista, after installing Vista SP1.
Thanks
Regards.
Jun 25, 2008 | Compaq Computers & Internet
Not possible xp installation
How to Downgrade Vista to XP Downgrading from Windows Vista to Windows XP is almost like installing Windows XP for the first time. You should take all the normal precautions like backing up all your important files and record important passwords in a different place, preferably on a CD. When you downgrade from Windows Vista to XP, note that Windows Vista will be completely removed from your system.
(Note: There is a way to have both Vista and XP in a dual boot configuration, but that's an option for more advanced users. See Dual Booting Vista and XP for more info on that.)
Before you begin the XP installation, make sure that the necessary XP hardware drivers are available, or included on the XP disk provided by your PC vendor. If in doubt, check the vendor's website or poke around with your favorite search engine to see if others have attempted the XP install on the same hardware. You may be able to install XP without all the needed drivers, but some hardware may not work afterwards.
Also, make sure that you have a genuine Windows XP CD before you begin the downgrade. Be sure to read the section earlier in this article to see if you qualify for a low/no cost XP recovery disk from your PC vendor. If not, perhaps you have an XP disc that came with another computer. If you've upgraded an existing computer from XP to Vista, the best choice would be the XP install/recovery disc that came with that computer. One some PC's the vendor doesn't ship a CD, but the recovery CD can be created from disk images on the hard drive. If all else fails, you can always buy a copy of Windows XP on Ebay. Just be sure it's a legal, licensed copy.
Follow these steps to install Windows XP on your Vista machine:
  • Insert your Windows XP install/recovery CD and restart your computer.
  • Install Windows XP normally, providing either the product key that came with the disk, or the one you got from Microsoft customer support. If the installer warns you that another copy of Windows is already installed, don't worry. Remember, this install will wipe out your existing Vista installation.
  • Activate your copy of Windows XP when it prompts you to do so. If you run into the "already activated" problem, you can use the option to activate by phone.
  • If you own Vista Business or Vista Ultimate, explain to the rep that you want to use your Downgrade Rights to install XP Pro.
  • If you own Vista Home Basic/Premium, or you are installing XP Home Edition, don't mention ANYTHING about Vista. Just give the rep your XP product key (not the Vista key), explain that you are installing XP on a new hard drive, and tell them you need to activate.
Mar 30, 2008 | Computers & Internet
Change of os
it is not possible to upload xp when vista has already been installed.
if you want xp & vista both in your system
remove vista
install xp
& later install vista .
it is not possible to upload a olderversion(xp) when you have newer version(vista)
you can download windows xp from this link
http://www.soft32.com/download_992.html
Dec 18, 2007 | Microsoft Windows Vista Ultimate Edition
Open Questions:
See all Dell Inspiron 1525 Laptop Flamingo Pink Questions
Dell Inspiron 1525 Laptop Flamingo Pink  Logo
27 people viewed this question
Alun Cox
