Question about Denon AVR 3808Ci Receiver
Fuse sizes for denon avr 3808ci 7.1 channel rec.
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
  • 395 Answers
SOURCE: Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
Posted on Jan 13, 2008
petraman7
  • 1175 Answers
SOURCE: Manul denon avr-1601 en castellano
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Espagnol as well ...I think
Posted on Feb 16, 2009
lynchms
  • 93 Answers
SOURCE: 5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Posted on Feb 22, 2009
  • 3 Answers
SOURCE: Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
RC-1068 preset codes
My self have problem with Denon AVR 3808Ci Receiver, the HDMI is doesnt work anymore, and I can not find replacement parts because receivers is out of date, very shame
Mar 30, 2014 | Denon AVR 3808Ci Receiver
I have a denon avr 3808ci and all of a suden im not getting sound frome sub.?
I'm having the same problem. Changed the wire from LFE to LFE input to the sub... I have a velodyne which has always worked great. Connected the sub with the original wire to my sony amp and it works great so it's the output on the amp. Any suggestions
Dec 08, 2012 | Denon AVR 3808Ci Receiver
How to hook up a denon avc 500amp to a denon avr 3808ci receiver?
To add more power to your systems connect AVC500 amp AUX input to
AVR 3808C "Rec Out", or any of the audio "out" s you may want to
connect ( back of the receiver)
use RCA plug on both ends of the cable.
Enjoy and Have a nice day!
Nov 02, 2012 | Audio Players & Recorders
How do I configure my denon avr3808ci to play 7:1
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-3808CI-Receivers-manual/id/3124dj391/t/2/
First, you must have all 7 primary speakers plus a powered suboofer attached. Page 9
Page 25 describes how automatic detection and adjustment is achieved. Page 28 for manual speaker setup.
Assign digital inputs. Page 39.
Then feed it appropriate 7.1-compatible material. page 40
Feb 28, 2011 | Denon AVR 3808Ci Receiver
I cant turn off the closed caption on my avr-3808ci...???
The receiver has nothing to do with that since it doesn't actually tune the station or decode the video content.
Usually, it's the TV that deals with CC.
Feb 09, 2011 | Denon AVR 3808Ci Receiver
Hit some buttons, now i can get 7 channel output.
Get into System Setup and run through the Speaker Configuration routine. My bet is it thinks you don't have Surround Back speakers.
Apr 24, 2010 | Denon AVR 3808Ci Receiver
I need a Denon AVR-3808 Service Manual
try doing a google search for avr 3808 manual
also try going to denon.com if you need a hardcopy call denon tell them to send you one.
Feb 18, 2010 | Denon AVR 3808Ci Receiver
How do I set up outdoor speakers? I currently have them set on Surround B, but do not seem to be able to play them
Fined in owner's manual section about MULTI ZONE CONNECTION AND OPERATION. page 68. If you don't have a manual, download it from here : http://www.usa.denon.com/AVR-3808CI-OM-E_404A.pdf
Nov 08, 2009 | Denon AVR 3808Ci Receiver
Protection circuit momentary activation. Not heat/speaker problem
Is it possible for you to lower the source level? if yes go ahead...
There is an automatic Dialogue normalisation function in Denon which is activated to reduce overly bright input signals. ( most movies have wide variation in sound levels and therefore this function is avaialble). (see page45 of your user manual).
When your system worked fine with the AVR 2808CI, then why is it giving problem with AVR 3808CI....???? You must ask Denon.
Protection circuits are activated when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
or
4). the set is damamged or has bad solder / dry solder connection .
If your AVR is new, please do not accept, the set could be faulty. The protection circuits should not be activated unless any of the above happen.
You must know, at times the protection circuits are not fast enough and it could burn some of the transistors on the power output circuit. With time, the solders on the circuit board could give way and give you problems later on.
You must sort out with Denon if the AVR is under warranty.
Best of Luck.
Mar 11, 2009 | Denon AVR 3808Ci Receiver
Blown Channel on an amplifier
Look for low valued resistors that may look ok, but be open. Check the emitter resistors (.22 or .47 ohms). Check the transistors in the driver circuit as well.
Dan
Jun 06, 2008 | Denon AVR 3808Ci Receiver
Denon AVR 3808Ci Receiver Logo
81 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
