Question about Nordic Track Incline Trainer X9i Interactive
Our belt is slipping on our nordic track x5i - Nordic Track Incline Trainer X9i Interactive
  • 103 Answers
SOURCE: belt on nordic track exp 1000 not moving
if you hear the motor moving with no belt turning the problem is either the front roller or the drive belt. If there is no motor movement then this is usually an indication of a bad control board located under the lower section of the treadmill.
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: how do you adjust or tighten the belt on the
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
Posted on May 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
  • 3 Answers
SOURCE: My Nordic Track A 2050
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Posted on Dec 21, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
Have the Nordic Track ASR 630. The belt slipped off. We fixed that. Now, the display will come on but blink off and on and then go off.
Check whether the belt is over tighten or not. If so by consuming over current this problem can occur. Try to loose the belt and check whether display shows the same symptom. If not then tighten the belt without become over tighten.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 29, 2016 | Nordic Track Exercise & Fitness
Why would the motor belt keep slipping off
Usually if a belt slips off the pulleys, it's because of misalignment.
The belt is not tracking true, pulling to one side.
Jun 05, 2014 | Nordic Track Nordictrack C2100 Treadmill...
How to adjust belt?
If you are adjusting the walking belt that much (7 complete turns) it sounds like the drive belt the small rubber belt from the motor to the front roller is really loose. You should only have to adjust the walking belt 2-3 turns max... you do not want to prematurely stretch your walking belt!
May 14, 2014 | Nordic Track Exercise & Fitness
I have a Nordic Track Commercial 1300 eliptical that started slipping when we used it. We tightened the belt but it didn't help. What else could be wrong?
Step 1
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Step 2
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Step 3
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
sincerely. Merry Christmas.ernesto cuadra
Dec 18, 2011 | Nordic Track Exercise & Fitness
Nordic track c2000 belt slips
I would try to tighten the rear roller a little and see if that helps.
1 start the treadmill and operate it at 1.5 mph then hild onto the handle bar and plant your foot against the belt at the front. If it slips tighten the roller 1/4 turn on each side. Then try the slip test again and repeat the process, do not tighten it too tight that will cause the belt to fold in teh center and be ruined. You May quite possible need a new belt. Take the belt lose and look at the underside and see if it;s glazed (shinny) or has pieces missing under the center of the belt, if so replace the belt and also clean the rollers front and rear, also flip the deck over it shoudl have a wax coating on the other side if that hasn;'t already been done.
Oct 23, 2011 | Nordic Track Exercise & Fitness
My Nordic Track A 2050 is slipping. At first I noticed it slip from time to time in my 45 minute workout, but at the end, it was like I was on ice. I love this treadmill, is there a way to fix it?
Dec 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Feb 05, 2010 | NordicTrack Exercise & Fitness
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
Sep 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Incline Trainer X9i Interactive Logo
61 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
