Question about Krell KAV400Xi Amplifier
Krell kav 400 xi cracking low volume won't turn up
Dial works good goes up but volume very very low
dunnbiker
  • 8546 Answers
SOURCE: Hi, Will the krell kav 500i work on 220v 50hz
If it has a voltage selector for 220v, once configured it will work just fine Being electronic instead of mechanical the power frequency won't affect it. If it doesn't have a voltage selctor, don't plug it into 220.
Posted on Dec 26, 2009
supertech6
  • 513 Answers
SOURCE: Hello, after plugging on Ipod through my preamp
Sounds like the volume was way up when the iPod turned on. iPods are DC and cause a sudden thump through the speakers when they power on.
If the fuse is not blown, there may be another fuse you have not seen. Most amps have three to five fuses especially a 150watt/channel like the Krell.
Posted on Apr 17, 2010
petraman7
  • 1175 Answers
SOURCE: Not enough bass response, how do I increase the bass?
Check the Krell website
  • 4234 Answers
SOURCE: Hello If i wanted to refresh my Krell KAV-300i
Can you please provide more information about what you mean by "refresh"? Is there a performance problem or funcitonal problem with the unit?
Thanks,
Dan
Posted on Aug 17, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a Krell KAV-400xi
Try to plug it in other known working outlet, if still the same symptoms, this is an indication that there's a faulty parts inside the unit. First thing to check is the internal fuse of your unit (I'm assuming here that the unit has no led light at the front panel), if it is already out of warranty, open the top cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with same current(ampere) rating and then power on the unit again... Sometimes fuse fail because of voltage surge to guard other parts...
Jdvillanueva
Posted on Sep 04, 2011
Main menu screen won't stay up on my krell showcase
If the main menu comes and goes off then it is possible that there is a fault in the processor memory. Try and reset with the given code- refer to manual, if not switch off set for about 6-12 hours and press down the panel buttons to drain off all residual voltage . this might help to reset.
Jun 06, 2012 | Audio Players & Recorders
Radio on 2008 dodge nitro stops working it goes out for a while then comes back on. no sound even when turning the volume up and down. it makes a loud popping noise and goes out.
Im having the same problem! No pop, just a hum, and my volume dial won't adjust. Like the actual dial isn't working. I can't use radio, cd, or aux. Silence SUCKS.
May 31, 2011 | 2008 Dodge Nitro
Hi, I have to replace all the 20 transistor of my krell kst-100 power amplifier- wich are the best choice? model and company? maybe mj21195g and 6 from onsemi?
Onsemi ( which is motorola) is a good pic for replacements If youre looking at the 21195 , then there must be a compliment to that as well? 21194 or 21196
Oct 10, 2010 | Krell KAV-300i 2-Channel Amplifier
Hello If i wanted to refresh my Krell KAV-300i what parts should i change out? Thanks :)
Thanks,
Dan
Aug 16, 2010 | Krell KAV-300i 2-Channel Amplifier
Hello, after plugging on Ipod through my preamp hooked through my krell kav 300 integrated amp I heard a super loud noise and lost power. I examined the fuse and it looks fine. What do I do?
Apr 17, 2010 | Krell KAV-300i 2-Channel Amplifier
Hi, Will the krell kav 500i work on 220v 50hz supply? Thanks
Dec 26, 2009 | Krell Audio Players & Recorders
Krell kav300i, increasing volume by itself.
That is an extremely odd problem. I suggest finding a tech in your area who is familiar with the unit, or contacting krell directly.
Sep 21, 2008 | Krell KAV-300i 2-Channel Amplifier
Krell KAV400Xi Amplifier Logo
65 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
