Question about Kyocera Mita KM-2050 Printer
I have Kyocera Mita KM-2050
How can I set default home-directory for my scanjob??
  • Kyocera HP Expert May 11, 2010
    please can you make your question more clear, thanks
    Sniper:
  • 66 Answers
You need to get the i.p address of your scanner and access it from your browser.
on the bottom left of the command centre menu you will see SCAN TO PC  "destination" .
put your details in new screen. if you are using a static i.p address for your pc put that in.
if you are running dhcp you should use the host name of your pc
Posted on Mar 10, 2009
Tip
Problem: My Mac Does Not Work With VantagePoint Possible Solution: If your Mac...
<span style="font-weight: bold;">Problem: My Mac Does Not Work With VantagePoint</span><br /><br /><span style="text-decoration: underline;">Possible Solution:</span> If your Mac does not work with Vantage Point, please try this technique.<br /><br />Please try to use "Parallels". Parallels will allows you to use your Mac home as the Windows home. <br /><br />In your configurations for the Virtual Machine in Parallels make sure that the default is set to use your Mac home for the Windows home folders.<br /><br />You need to uncheck the shared profile so that Windows has its own home directory. You can now run 10.6.2, Parallels 5 and Windows.<br /><br />This solution also works for Mac OSX 10.4.11 - Parallels 4 - VP 1.60<br /><br />JG
on Dec 08, 2010 | GPS
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
Jul 22, 2016 | Polaroid 7-in. Internet Tablet - Other
Lost the pin code for kyocera 2050
The default code for the Kyocera KM-2050 is 6482.
Jun 30, 2015 | Kyocera Mita KM-2050 Printer
How do i reset my macbook screen appearance
It depends one what you mean. I'm taking a guess here, but I'm assuming you mean your desktop appearance, like desktop icon size, arrangement, font size, etc.
All this settings are set in .plist files located in your home directory Library. Go into your Users folder and navigate to the Library folder and then to the Preferences folder. Look for the com.apple.finder.plist and the com.apple.dock.plist. Rename this files and then restart or logout. When you log back in you should have default settings again.
Mar 27, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The directory name c:\user\nimra\local\application data\google\chrome\default is in valid please help me how i can remove this problem
I would recommend uninstalling it and when asked remove user data as well and reinstall chrome. The default user profile has become invalid.
Oct 10, 2012 | Dell Computers & Internet
Whats the short cut to get to calc screen
If by calc screen you mean HOME you usually get back to it whenever you interrupt the execution of a command. You can also go to HOME by pressing RIGHT SHIFT (Cyan) key then the appostrophe (below MTH). That returns you to the HOME directory. To set the menus to the default ones, press MTH
Apr 19, 2012 | HP 48gx Calculator
Kyocera Mita KM-2050 Printer Logo
933 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
