Question about Exercise & Fitness
New balance 1600,turn it on and the incline goes up then back down a ways,then gives me an err3 code,tryed the saftey switch,repeats the same thing ,cant get the belt to turn no matter what i do
I did have the treadmill working the other day even though the error message was on,now nothing,any help??
    Top Expert:
  • 12,223 Answers
Adjust the speed sensor, test for open or faulty, clean it, and tight the plug very well.see the diagram attached.
However RUN the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
new balance 1600,turn it on and the incline goes u - 12_11_2012_2_46_08_pm.gif12_11_2012_2_46_29_pm.gif
Posted on Dec 11, 2012
  • Bob Bhaphe Jun 28, 2013
    When you say "RUN the software", what software??
SOURCE: Replace Switch error message
It was the emergency tag that you attached to yourself when you run (in case you fall over - the belt then stops etc). i had not connected it properly
Posted on Jan 27, 2009
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jul 16, 2010
What is wrong with and how can I fix the incline on my Nordictrack commercial 1750 treadmill?
This sounds as though the motor is bad, they cost around $130.00, ther is a n electronic controller that controls it, but as it is trying to raise I would think that the switch and controller are functioning. Best of luck and please post back f this helps.
May 25, 2014 | Nordic Track Commercial 1750 Treadmill...
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
Can not get the incline to go all the way down,so I can fold it up
please go to the HOOD motor, and see the instruction for to RUN the software calibration for easy diagnose, troubleshooting, and fix it.
Sep 03, 2012 | New Balance Balance 1500 Treadmill
Treadmill power incline stuck in upper postion after power outage
RUN inmediately the software calibration for diagnose, troubleshooting and fix it easy.
God bless you
Jul 11, 2012 | Proform Exercise & Fitness
I have proform 545s treadmiil and incline engages as soon as the saftey key is put on and will not stop. My wife stopped the machine while it was inclined then folded it to store it.
Hello there. The machine is trying to complete an incline calibration.
Place the kay back on the unit and allow it to go all the way to the top then all the way back down and it should be ready to use.
If you stop the machine while its in this mode it will start the process all over again.
Good Luck! Tim
Jan 15, 2010 | Exercise & Fitness
My ProForm 530 is stuck in the incline position. Once the key is inserted, the treadmill is steady trying to incline past 12 and does not respond to me pressing the ''incline down'' button. It continues to...
plug her back in, insert key, let her do her thing while u just sit back- I believe shes trying to Calibrate. If so, she will go up all the way,then back down on her own. after she's in down posistion, console will beep/beep and she has reset herself.. let me know what goes on after u do this. David
Jan 05, 2010 | Exercise & Fitness
My key will not turn in the ignition. What could
u are going to have to replace the ignition key lock assembly, a pin is damaged, this just happens, no paticular reason i have found yet.
Nov 18, 2009 | 1996 Chevrolet Cavalier
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
May 29, 2009 | Whirlpool Microwave Ovens
Exercise & Fitness Logo
51 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
