Question about Dryers
Frigidaire affinity dryer putting holes in clothes
    New Friend:
Its probably not your dryer. I had the same problem and it turned out to be the washer itself. The agitator[probably not spelled right] needed to be adjusted. I could not see the holes when taken out of the laundry only when dry. If not in right position little metal clips under agitator hook on cloths and rip them during wash.
Posted on Dec 11, 2012
  • theresa goodwin Dec 11, 2012
    Was this something you could fix yourself, or do you need to call service?
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
  • 193 Answers
SOURCE: my frigidaire affinity front load dryer shows the
AD is a indication of board problems.I would unplug the unit for 20 minutes to see if unit will reset
Posted on Nov 10, 2009
Jahn27
  • 1554 Answers
SOURCE: I have a Frigidaire Affinity Clothes dryer
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Posted on Mar 07, 2011
Why is my Affinity dryer not heating as well as it was put new dryer hose in back just taking touble time to dry a small load of clother & I double spin the load also
Good Morning Friend,
I understand that your Frigidaire Affinity dryer is taking double the time to dry a small load of clothes. I also see that you have put a new dryer hose on the back of your appliance to try and correct this issue. I suggest making sure that you have also cleaned out the lint filter as well as where the lint filter sits. You can clean the lint filter by running it under the hottest water you can stand and using a cleaning brush, gently, to remove any build-up. You can clean where the lint filter sits with a small attachment on your vacuum. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
My Frigidaire Affinity dryer keeps wrecking my clothes by breaking straps
In any front load machine, whether washer or dryer, the manufacturer will suggest to have the items with buttons or straps, or small items, put into a mesh bag. Now you can have a professional check to see if you have too much of a gap between the drum and the door itself.
Jul 27, 2012 | Frigidaire Dryers
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
Mar 06, 2011 | Frigidaire Electric Dryer
Metal on metal sound. we have a frigidaire affinity
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 26, 2010 | Electrolux Frigidaire Affinity AGQ8700FE...
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Holes in clothes
no yo may have a pin or needle type stuck in your dryer and when clothes go around they get stuck on it cheack drum very carefully
it may be a bra wire that jammed in between drum
Jun 17, 2009 | Electrolux Frigidaire Affinity AGQ8700FE...
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
Top Dryers Experts
