Question about Pyle 12" 600 Watt Amplified Subwoofer Tube System PLTAB12 Car Speaker
HOW TO INSTALL
INSTALL A 12" PYLE AMPLIFIED SUB TUBE IN EXT CAB TRUCK
  • 44 Answers
I would say look for a custom box off ebay or build one behind rear seat. Im not shure if you can fit a small truck box behind there but you may be able to. It would sound pretty good behind rear seat. Hope this helps
Posted on Jan 13, 2009
How much airspace does Pyle PLBW154 1500W 15" Blue Wave Series Dual 4 Ohm Subwoofer need?
If its going in a single cab truck you won't have enough room. In a car you will need at least six inches. Might consider soundproofing the trunk if that's where they will be BC the vibration from the base will bounce off the walls and can blow your speakers??
May 30, 2015 | Pyle Car Audio & Video
I have a blue pyle 12 inch 800 watt tube for my car. I've wired everything perfectly, yet when I go to turn on my radio, it doesn't work. The blue lights cut on, but the speaker itself puts out...
it could be few things one the light might come on but the preamp could be bad two could be a loose wire to sub three sub could be bad four make sure rca cables are good i hop this helps
Feb 21, 2013 | Car Audio & Video
I am trying to hook up 3 kicker subs with a pyle 1400 watt amp in my 98 Eddie Bauer explorer and i am not sure how to do it because it has the stock amp in the back passenger quarter panel
First off, you won't be able to do this with a Pyle amp. Pyle amps are only 2 ohm stable (at best). When you do a 3 sub set up (assuming that they are all single 4 ohm voice coil), you will get either a 1.33 ohm load (way to low for that amp and will fry it quick), or you will get 12 ohms (hardly worth hooking up because of the lack of power).
Now say you have dual 4 ohm subs. You will still have the same problem going even lower than the 1.33 ohm or 6 ohms.
My recommendation is either do a 2 sub set up or get a better amp.
I know it's not what you want to hear, but it's true.
Aug 29, 2011 | Car Audio & Video
I want to install a self powered woofer and tap it to the rear speakers. Can you please tell me what are the colors and polarity of the rear speaker wires for 2006 Honda odyssey right hand drive
FIRST OF ALL --- THERE IS A FEW THINGS YOU NEED TO KNOW BEFORE HOOKING UP
A WOOFER LIKE THIS ---- IS THIS A STORE BOUGHT POWERED SUB WOOFER ? DOES IT HAVE IT'S OWN CROSSOVER BUILT INSIDE ?? I WOULD GUESS IT NEEDS TO BE HOOKED
UP TO A SUB WOOFER OUTPUT FOUND ON THE BACK OF THE IN DASH PLAYER ..
THE WOOFER NEEDS TO RECEIVE ONLY LOW FREQUENCY AUDIO WHICH MOST OF THE NEWER CAR STEREOS PROVIDE BY AN RCA JACK ON A SHORT WIRE COMING OUT OF THE STEREO ...
IF YOU TRY AND TAP IT TO FULL RANGE SPEAKERS THAT ALREADY ARE CONNECTED TO AN AMPLIFIED SIGNAL THE SOUND WILL BE DISTORTED .......
POWERED SUB WOOFERS NEED A LINE LEVEL INPUT WHICH IS MUCH LOWER THAN SAY
SPEAKERS ALREADY RECEIVING AN AMPLIFIED SIGNAL.
POWERED WOOFER WILL ALSO NEED TO HAVE A 12 VOLT ELECTRICAL CONNECTION AND A GROUND WIRE TO OPERATE THE AMPLIFIER BUILT INSIDE.
IF YOU HAVE NO EXPERIENCE WITH THIS TYPE OF HOOK UP I WOULD STRONGLY RECOMMEND SOMEONE WHO DOES [ CAR AUDIO SHOP ]
Jun 29, 2011 | Car Audio & Video
I have a pyle 12"
I am afraid in order to make use of your sub, you will need to buy an amplifier and a cabling kit to run it. You could run it straight from the headunit from one of the main channels but it would need a crossover so it wasn't fed any sounds which it couldn't cope with (high frequencies, they require very fast movement of the speaker cone, your sub wouldn't be able to do it)
Here is a link to a downloadable copy of headunit manul.
Hope this helps
May 09, 2011 | Pyle Car Audio & Video
I have a 10" pyle
+ to + but if your amp shuts off and turns on switch it to + to -
May 05, 2011 | Pyle Car Audio & Video
I have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
Dec 24, 2009 | Pyle 12" Molded Blue Cone High Power...
Shifter feels like it is broke and truck is in gear, how can I get truck in park
get under your truck then feel on the side of your gear box and there is ia lever about 3 inches long this is your selector it should be attached to your shifter if it IS still attached then your gearbox is fooked
Dec 14, 2009 | MTX Dodge Ram Quad Cab 2002-2003...
Custom install of pyle red label sub
Start here: http://www.fiberglassforums.com.
Go to the "How to Make a Sub Box Mold Thread" and look over some of the photos.
Building a trunk box for a single sub is a great first project and depending on the time and attention to detail that you put into it, the results can be really fantastic.
Also take a look at the "Tools of the trade" thread. There's tons of good information and ideas on the fiberglass forum, including sources for materials step-by-step photo logs of various projects.
Hope this helps and that you enjoy your new DIY sub enclosure.
Good Luck!
Mar 24, 2009 | Pyle Red Label 12" Square Subwoofer Car...
Can you tell me the correct specifications for a speaker box for a pyle PLSQ12D want the best sound possible!!!!
hey found the answer to your question while looking for mine own, heres is the link to the pdf. it has all the specs from the company(pyle) dealing with the 10,12 square sub.
the info you are looking is under the category/ Vas (cuft.) which if i am reading correct to get the best sound you would need to build your box with 4.14 cubic feet. but look for yourself
http://www.pyleaudio.com/manuals/PLSQ10D-12D-PLW12DREN.pdf
Lance
Mar 05, 2009 | Pyle Red Label 12" Square Subwoofer Car...
Car Audio & Video Logo
211 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
