Question about Samsung DVD/VHS/MP3/SVHS Playback
Using your television as a moniter for your computer
I know this can be done but the problem is it says u need a s video cord, rca cables, or a converter Which you do but what will give me the best picture and quality im looking for,for the best price even if its just a cable i dont have a svideo hookup on the back of my computer so i was looking for something that goes through the vga or moniter connecter to like the back of my samsung vcr to like a svideo or the rca cables or even better the red, green, and blue cables which people say gives you the best quailty and picture Ive looked everywhere but cant seem to find anything that works for me so this is a problem if anyone could help this would be greatly appriciated and yes i know that the picture isnt going to be the best because of resolution factors but i dont have to buy a pricy moniter
    Genius:
  • 1,074 Answers
Check www.repairworld ,dalbani.com parstore.com they might have what you are looking for
Posted on Jun 11, 2007
SOURCE:
My Wii U wont work on my RCA TV!
U will need to get another av ..connecter...the color cords you said..there rca jacks..then it will work
Jul 29, 2014 | Nintendo Wii Video Game Consoles & Games
Connect wii to vga moniter Hp s2031
Hi Dear Friend,
You have a monitor with in-built VGA Port and you have laptop in-built VGA Port then why you are not using simple VGA cable to both port, Please don't use any other type to Adapter.
Thanks to Visit on Fixya
Sep 13, 2012 | HP S2031 20-inch Diagonal Lcd Monitor -...
There's a buzzing sound coming from our RCA Scenium tv, how do we fix it?
Are you using RCA type audio cables?, if so, make sure the connectors are tight and the cables are not frayed, it also helps routing those analog cables at least 8 inches away from any power cords or transformers. Buzzing usually is caused by loose ground connections or RF interference.
HDalacarte.com guy, audio/video/computer technician for over 30 years
May 26, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Got a svga/hdmi cord and hooked up for my panasonic viera plasma to my computer but nothing shows on my component 2. also wondering if i'll need a cord for audio - i have double red/white/yellow...
You probably would need the extra audio cords seeings as normal svga connection won't suppost sound streaming. mixing and matching connections is always a pain to perfect.
If you are using the HDMI end on your plasma, then you will have the video show up on the HDMI channel. Then get an RCA red and white pair - 3.5mm jack and plug the jack into your PC's audio connection port and the RCA's into the Audio In ports in the back of the TV.
Once done the TV should display video and play sound from the PC. Failing this, try a few different configuration but always keep the audio plugged into the same Audio in port on the TV. Bacause then you at least know the channel that the audio works on ;D
Hope this helps mate, any more q's just ask!
Nov 23, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Pc to tv
if you PC has one of the following outputs then it will work ...
composite (rca jack) , S-Video , HDMI or component (three wire rca jack) ...
several video cards have at least composit video out as well as the normal VGA output . look for a single RCA.jack ....
if your video card does not support any of these formats then you would need a VGA converter box to one of those formats ... there is also a USB to s-video/composite converter cable ...
the resolution of your set is 1024 X 768 ... so thats what you would set the video card for ..
Apr 12, 2010 | Sanyo DP42746 42 in. Plasma Television
A/V cable
Hi and welcome to FixYa,
On most handheld TV units, the A/V input requires a 3.5mm stereo baby phone plug. While on most projectors, the Video out is a composite single RCA jack. What would be needed then is a 3.5 babyphone to RCA cable/adapter.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 02, 2009 | RCA L1800BC 1.8 in. Handheld Television
How to hook this monitor onto my computer
You would have got a CD with this moniter..
we ahve install that cd..
and its better to check the cables first which would be the
VGA CORD that is blue in colour which connects your moniter with the tower.
We can check the connections with the moniter for the Tower and then install the cd.
Feb 06, 2008 | Computers & Internet
Connect Playstation 2 to computer monitor
try going to your local radioshack and asking for a cable to do it. Tell them it needs to be "double male" infering that the piece sticks into another part instead of bieng stuck into. Then tell them one end needs to be "RCA cables" (the red white and yellow ones) and the other end needs to be a computer moniter cable. There are several types of moniter cables you can use, look in the back of your moniter to see what you have. There should be writing that says any 1 of the following "s video in", "dv in" "video in" etc. ask the radioshack man to get the non RCA side of the cable to have one of these on it. If you need to, it helps to take a picture of the back of the moniter where all the input plugs are, and show it to the radio shack man, he can probably help decide which cable to use. Once you buy the cable, plug the red yellow and white side into the red yellow and white holes respectively on the PS2, and the moniter cable into the moniter. Turn on the moniter and the PS2 and... Voila. PS You may need to take out the cable connecting the moniter to the PC to put in the new radioshck cable. I hope this works for you-BCA
Aug 26, 2007 | Sony PlayStation 2 (PS2) Console
Samsung DVD/VHS/MP3/SVHS Playback Logo
21 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
