Question about Acer Aspire 5250-0639 1.65GHz AMD Dual-Core Processor E-450 with AMD Radeon
Connect hard drive to usb - Acer Aspire 5250-0639 1.65GHz AMD Dual-Core Processor E-450 with AMD Radeon
  • Acer Master
  • 32,281 Answers
You need to install the hard drive into an USB hard drive adapter case.
Posted on Dec 11, 2012
Transfer stuff from a working and put it on another hard drive
The easiest way is to connect your hard drive to an USB hard drive adapter or USB hard drive dock, then plug this USB adapter ot dock into the USB port of your computer. The computer will see this as an external storage device, you can then open the various folders and copy the folders or files to the computer,
If you want to copy these folders or files to another hard disk then connect the other hard drive to the USB hard drive adapter or USB hard drive dock and plug it into your computer and copy the folders or files from your computer to the external hard drive.
Mar 28, 2013 | Maxtor Hard Drive
Can I connect a WD1600 Hard Disk via USB connector for external drive?
You need to purchase an USB hard drive adapter case and install your hard disk inside this case. Take your hard drive with you when you got to a computer shop so you will get the correct IDE or SATA USB adapter case.
Mar 26, 2013 | Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Mon pc ne reconnais plus my boock
Please try to disconnect and reconnect your usb hard drive is this hard drive working normally before. Try also another usb connection like flash memory to check your usb connection. If there is no problem with other hardware you may have your usb hard drive malfunction.
Regards, Jay
Feb 15, 2011 | Western Digital My Book Essential Edition...
Computer will not recognize hard drive
uninstall and reinstall the drivers for USB ports
or try connecting the hard drive to some other ports and check if it is working
if it works in other ports then the problem is with that particular usb port
or try connecting some other usb devices to the same USB port, if those devices work then the problem is with the hard drive
Thank you
Jan 06, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
How can I turn my netork hard drive into a External hard drive
Network hard drive is also an external har drive but its shared over a network. If you want it to be used a external hard drive connected directly to you computer, read below.
Your WD drive should have a USB port on it. You need to plug the drive into your laptop directly to be used as a external hard drive.
Please rate if helpful.
Thanks
Apr 19, 2010 | Western Digital My Book Essential 1TB...
I need to run an HDD2159 external of its computer.
You cannot just connect the hard drive using a SATA to USB cable and connect it to the computer and expect to download data from this hard drive.
You need to connect the hard drive to an USB hard drive adapter which is then connected to a computer's USB port?
Leave the hard drive set as the master drive.
Oct 02, 2009 | Toshiba MK 3017GAP (HDD2159) 30 GB Hard...
Hard drive doesnt turn on
It appears that your USB hard disk is drawing power that exceeds what the computer's USB port can deliver.
If your USB drive has a power adapter, connect it to your USB drive before you connect it to the computer's USB port.
If your USB drive does not have a power adapter/connector then you need to insert your USB drive into a USB hub that is powered from the mains adapter. Connect this hub to your computer's USB port first and then connect the USB drive into the powered hub.
If none of this works then it is possible that you have a faulty hard drive. If possible test this drive in a computer, use a old computer.
Dec 02, 2008 | Acomdata Computers & Internet
Acer Aspire 5250-0639 1.65GHz AMD Dual-Core Processor E-450 with AMD Radeon Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
