Question about Carrier Heating & Cooling
My carrier indoor blower motor trys to engage but doesnt. slowly spins cw then ccw..even with heater or ac off..Just fan on..it does turn off if you turn fan off...model #fv4anf003
3 Suggested Answers
  • 13 Answers
SOURCE: Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
With power off, locate fan motor capacitor (generally silver in colour).
Rating on capacitor will be in microfarads at specified voltage ( 5mf @
370 volts). Be careful to discharge before handling and return defective
cap. to source of replacement. They can confirm whether or not truely
defective. Replace and secure. Restore power and check operation.
Purpose of run capacitor is to provide starting torque that you are
presently providing by hand spinning. Hope this helps.
Posted on Aug 05, 2009
  • 55 Answers
SOURCE: First time using the AC. Won't go on. Heater works.
lower temp setting lower then outside temp should work
Posted on Aug 06, 2009
Looking rearward towards front of engine from in front of radiator, which way, CW or CCW, does 87Ford Ranger2.9L crankshaft (fan & pump) turn?
fan clutches are Left hand thread as they tighten up when the engine is running. If they were right hand thread then when the fan is working they would come loose off the shaft
In short undoing then actually tightens them
Jan 11, 2015 | Cars & Trucks
Tip
Fan Clutch R&R With Confidence Using Griller....Glitter Tool
...ever found you self asking which way to turn a mechanical fan clutch's inline coupling nut to remove clutch-fan assembly (It) without mangling a thread or special wrench? Well then, consider the Griller...Glitter mnemonic system described below and never fail to be "thread-wise in the know."
If you know or can bump the starter to see which way the fan spins viewed from the radiator, then knowing any or all of the easy-to-remember devices below will let you get that clutch off, or on, with confidence. For instance, with a left thread clutch nut, the installed clutch-fan assembly will always spin right/clockwise.
Remember, you only need to remember the ones that are easy to remember.
    ·GRILR
    ·GOES RIGHT? IT LOOSENS RIGHT.
    ·If fan clutch spins right/CW, turn its nut right/CW to loosen.
    ·GRITL
    ·GOES RIGHT? IT TIGHTENS LEFT.
    ·If fan clutch spins right/CW, turn its nut left/CCW to tighten
    ·GLILL
    ·GOES LEFT? IT LOOSENS LEFT.
    ·If fan clutch spins left/CCW, turn its nut left/CCW to loosen.
    ·GLITR
    ·GOES LEFT? IT TIGHTENS RIGHT.
    ·If fan clutch spins left/CCW, turn its nut right/CW to tighten.
on Jan 12, 2015 | Vehicle Parts & Accessories
Heater doesnt work at all
replace blower motor and then see if there are other problems
Jan 12, 2013 | 2001 Mercury Sable
Have grinding noise in dash repeat over and over. sounds like CD trying to recycle but no CD inside and no cassette tape. it only comes on when ign switch on, no sound when key switch on access
I bet you have a leaf or leaves inside the heater blower compartment. The blower motor fan is always turning slowly even though the AC or fan is turned off to provide for ventilation. See if the grinding noise changes when you turn the AC fan on or off.
Dec 03, 2011 | 1998 Buick Park Avenue
My 1991 isuzu trooper heater blower fan is not working, nor when i turn it to the airconditioner the compressor does not engage. i checked all the fuses except the ac relay fuse block, what could the...
if the lower fan speeds dont work but the fastest speed does the heater fan resistor block needs replacing. If the highest fan speed doesnt work leave it on there and check for power at heater blower fan, if power is on one wire and the other is an earth the blower motor fan needs replacing. Use a normal globe test light to check this. If no power on any wires to fan go back and check all fuses in car and under bonnet with same test light. If fuses are ok possible open circuit wire to fan.
Jan 13, 2011 | 2004 Isuzu Rodeo
Will not spin during spin portion of cycles. it rotates slowly cw and ccw but no fast spin
It's either a bad door switch, or motor control board. Definitely easier and cheaper to try changint he door switch first, as it fails much more often. Part number is 131763202
Apr 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
I am replacing the electric motor in my gas dryer I have it disassembled, and am removing the fan on the back of the motor. does this fan turn counterclockwise or clockwise to remove
Look at your fan and the way the blades curve...to deterimine the rotation of the motor. They can run either direction... some run CW and some CCW....
Once you determine the rotation you can then determine the way the blower comes off. The motor will always spin to tighten the blow on the shaft..... so going the reverse direction would be the way to take it off.
I wish that I could give a definitive answer like yes it goes CCW... but that would not be the correct answer all the time...hope you understand....and that my explaination is clear...why it could be either way.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 02, 2009 | Refrigerators
The freezer is cold, but the fridge stays around 40 degrees, and the unit keeps running continuously
The evaporator fan motor may be about to seize and is running to slowly to cool the fridge, cost about ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Outdoor carrier cond. comes on but the indoor
Bearings in fan motro bad or bad capacitor. Depending on size of unit should be 5uf 370 capacitor. Replace cap. ans try to start unit.
Jun 10, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
