Looks like is taking paper only on one side, what is the problem?
SOURCE: canon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
SOURCE: Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
SOURCE: e5 problem
CHECK YOUR INK CATRIDGE E5 error means that- The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
SOURCE: why my scanner does not work?and my printer
Thats like asking why your engine works but your tires are flat. You need scanning software on your computer for the scanner to work, but if you just want a copy you press copy. It won't scan until it knows where to send the scan and how you want it scanned.
SOURCE: kept getting 'remove MP Paper' error message
I will like to know the solution to this problem.
