Question about KitchenAid K45SS Classic Stand Mixer
On my Kitchenaid Artisan mixer the 3" silver rod fell out the back. How do I slide back in?
    Novelist:
  • KitchenAid Expert
  • 185 Answers
I an sorry but the only Rod in the back of a K45SS is the pivot hinge pin that holds the motor head onto the base. if it fell out then the answer is simple. Turn the mixer upside down and wiggle the base while sliding the pin back in. Once the pin is back in place, there is a set screw in the middle of the shaft that you can see while you are replacing the pin, turn this back down with a flat head screwdriver untill it is firmly against the hinge pin. The culprit of the problem is this set screw. It came loose and allowed your hinge pin to vibrate out and then fall down or fall out as you said. once the set screw is back in place you will be fine. To avoid this problem in the future you might remove the screw entirely and put a drop of "Lock-Tight" on it that will help hold the setscrew in place for a very long time.
Posted on Dec 29, 2012
  • 12 Answers
SOURCE: KitchenAid Mixer Squeaking
I would first get some canned air. Spray out the area around the Shaft. This is to make sure no harden food is up there. After that is clean spray some cooking spray "PAM"in the Shaft area. This should help. Good Luck
Posted on Feb 11, 2008
SOURCE: the locking pin on the
I had the same issue. I just finished tearing mine apart only to find that the lock just wasn't engaging with a slot in the base of the mixer. Try lifting up the head of the mixer to expose the height adjust screw in the hinge between the base and the head. By tightening mine down a couple of turns, the lock can engage the slot again and the lock works. You may have to do a little tweaking to find the right balance between height adjustment and latch functionality, but at least you won't have to tear your mixer apart like I did!
Posted on Apr 03, 2009
  • 143 Answers
SOURCE: My Kitchenaid Artisan Mixer is leaking oil or
Your kitchenaid mixer is meant to leak a tiny amount of oil around the rim of the planetary gear on the front of the machine. This is just a means of lubrication. If however you are getting alot of oil coming out of the sides of the unit, the transmission gasket may be worn or broken if this is the case it will have to be replaced. part number for the gasket is 4162324. If your getting alot of oil from the center of the unit this could indicate worn or broken seals. there are 4 located inside the unit, and would need to be dismantled in order to replace. part number for all four is 3180163. If you are leaking alot of oil or grease continued use of the mixer might cause it damage. Hope this helps
Thanks
Posted on Nov 04, 2009
SOURCE: My KitchenAid Artisan stand mixer won't turn on,
It sounds like something is obstructing it or the lever is bent. You will need to take the head apart to investigate further.
Posted on Jan 24, 2010
  • 3 Answers
SOURCE: rod came out of neck
raise the top while sliding the pin back in. You will need to play with the correct angle in order to get it in all the way. mine won't go in if it's all the way down nor all the way up. it needs to be somewhere in the middle.
Posted on Feb 12, 2010
My Kitchenaid mixer (artisan) runs for 2-3 seconds then quits regardless of speed selected any suggestions
How long before it restarts again? I'd take the back cover off and have a look around and test for continuity in the relevant places when stopped and unplugged.
Aug 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid artisan mixer is loose and shaking
This could be the pivot rod between the head and the column being loose and out of place. Or it could be the hook activated by the lock lever not engaging properly. See the following Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mar 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Feb 16, 2013 | Kitchenaid 5 Quart Glass Bowl Artisan...
Kitchenaid artisan mixer
The most likely answer is that you need a new speed control switch and there is a possibility that you may need a new worm gear. Can you give a more detailed explanation? What happened last time you used the machine?, what was happening when the problem occurred? What caused you to open the back cover? what else did you inspect or take apart or open up? Please send more info.
Jan 03, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Rod came out of neck
Feb 08, 2010 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways round, there is a key on one corner which means it will only go in one direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
Sep 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My KitchenAid Artisan stand mixer won't turn on, the lever won't slide into the "on" position. It's only about 3 years old.
Mar 31, 2009 | KitchenAid 32685 Mixer
Mixer
i called kitchenaid. and i am repaired. lay mixer on its side. then you can see how rod needs to line up. loosten screw a bit if necessary. then tighten back up. very easy solution!
Dec 01, 2007 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
616 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
