Question about HEWLETT-PACKARD Hewlett Packard HP Pavilion Touchsmart 310-1020 AMD Athlon II X2 240e D - BT417AAABA PC Notebook
Black screen on hp touchsmart 310-1020
When I power up everything comes on, but nothing on the screen, what is the problem?
  • HEWLETT-PACKARD Master
  • 27,725 Answers
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Posted on Dec 11, 2012
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
  • Anonymous Aug 08, 2015
    Hard disk LED does not flash. So what could be the problem?
HP TouchSmart 310-1125f display is black
Hearing fans and hard drive spin up doesn't necessarily mean system is working - just without video. If you heard a POST beep or the Windows Startup sound that would be different - and good. Is there any video on the screen at all, even just a blinking cursor in upper left of display? If not, your problem is probably hardware such as ram or motherboard. If this system has a VGA or HDMI output to connect to another monitor or TV would be a good check, but AIO system usually don't have that option. Other than that, and this is a shot in the dark: Ensure the system is off, disconnect the power plug, and hold the power button in for 30 sec for a power reset. Then plug in system and try powering it up again. If no go, you may have a hardware problem and will need a PC Tech. Hopefully it is just loose ram.
Apr 08, 2015 | HP Touchsmart 310-1125f Windows 7 4gb Ram...
Black screen on HP Touchsmart 310, any ideas?
i guess your computer is suffering from Software Driver Conflict.
because in safe mode, windows does not load any third party drivers, but its own. so your computer turns ON.
it it NOT AT ALL any hardware related issue, so you dont need to buy/replace anything.
tell me more about your operating system and your computer details, so i can help you properly
Mar 04, 2015 | HP TouchSmart BV551AA 310-1125f Desktop PC...
Is there a fuse in a hp touchsmart 600-1120
No, computers don't have fuses. It could have a blown power supply (the thing the power cable is plugged into). Its rare for those to go, but its possible.. You'd have to have someone come over and check it.
Jan 03, 2015 | HP TouchSmart 600-1120 All-in-One PC Black
My HP Touchsmart IQ804 PC won't turn on. A few led lights go on, I know it's getting power, but nothing but black screen.
do you have the vga or hdmi cable plugged into the correct video output on the p.c. Some P.C's have a video output on the motherboard that could be disabled due to a VGA adapter card being added and the output comes from the card rather than the VGA adapter and plug socket on the motherboard..
Aug 24, 2014 | Computers & Internet
I bought this HP Touch Smart 310PC a year ago, the power is on and the screen is black nothing comes up.
You may have a disconnected GPU. The GPU is likely soldered to the motherboard and due to the thermal stress of heating and cooling, the contacts break. This is a major problem with HP. If this is the case you will need to have your GPU reflowed/reballed at the motherboard level.
If it's under warranty this will definitely be covered. Otherwise check eBay for "Touchsmart Motherboard Repair". It should cost between $50 and $100 for a repair.
Jul 24, 2012 | HP TouchSmart IQ770 PC Desktop
HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
Touchsmart tx2z Screen Flickers and Freezes
it seems the touch part is off center because when i touch the screen it reacts one finger over
Jul 09, 2010 | HP TouchSmart tx2z
Take Apart IQ770
Check out this web-site that was set up for "Touchsmart" owners; there are many discussions on this very topic there and one person has successfully fixed their IQ770 with a black monitor problem who has posted.
http://www.touchsmartdevzone.com/forum/thread/770/MONITOR-IS-BLACK-RESPONDS-TO-TOUCH-BUT-IS-TOTALLY-BLACK/?page=5#12182
Feb 25, 2009 | HP TouchSmart IQ770 PC Desktop
HP TOUCHSMART IQ770 BLACK SCREEN
Have you checked on the hibernation settings?
Dec 20, 2008 | HP TouchSmart IQ770 PC Desktop
HEWLETT-PACKARD Hewlett Packard HP Pavilion Touchsmart 310-1020 AMD Athlon II X2 240e D - BT417AAABA PC Notebook Logo
7,834 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
