Question about Sewing Machines
I had to order a new bobbin case for my singer 7028 but, cant get it in.
I bought a sewing machine, second hand, and it did'nt have the bobbin case, I ordered a new one, but I'm having problems installing it, does anyone know where I can find a diagram of how to do it? The manual doesn't help.
  • Sewing Machines Master
  • 1,564 Answers
Http://www.singerco.com/uploads/download/444_5_8_10_16_22_dial.pdf
Posted on Dec 15, 2012
SOURCE: Singer Concerto sewing machine model 9217 - bobbin thread problem
This problem is common in sewing machines with plastic bobbin cases. The new case you've ordered will most likely solve your problems. I might suggest checking the point of the rotating hook, to be sure it is burr free.
Posted on Feb 01, 2008
  • 3 Answers
i was having the same problem. try putting in a new slide plate - the pressure from it holds the bobbin down, but it wears thin after a while. fixed mine.
Posted on Mar 03, 2009
  • 4 Answers
SOURCE: Replaced Singer 5932 bobbin case, need help. *pics*
there may be uneeded friction occuring. are you sure you inserted it correctly? sorry. photos aren;t appearing. but it may be that it is the wrong type or in the wrong place. do some trial and error and fit it into different positions on the bobbin runner
Posted on May 11, 2009
  • 3 Answers
SOURCE: Singer 7442 How to get inside ?
http://www.scribd.com/doc/3713782/Singer-7442-Sewing-Machine-Manual heres your manual, good luck!
Posted on May 13, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
I have a Singer 6268. When I try to load the bobbin, the thread winds underneath the bobbin instead. What can I do to fix this?
change the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
make sure there is no burrs on the bobbin case or that the bobbin
case is not damaged
if none of these suggestions help, then it might be a good idea
to take the machine in to be check at a sewing machine shop
May 31, 2012 | Singer Quantum XL-6000 Computerized Sewing...
I have a singer 20u, the bobbin always drops when i put it in , i cant sew at all.please let me know how to fix it.
it's very possible that there is something wrong with the bobbin case or the hook & hook race, only a sewing machine shop can tell you for sure what wrong with the machine
May 29, 2012 | Singer 20u Sewing Machine
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
My new singer sewing machine(after I sew 2-3 pillow cases) Then top thread can not take out bottom thread from bobbin case. I can not stitch anything with only top tread. What is wrong? should I return...
I've been sewing for over 30 years & I would agree the machine needs to be returned & get another one, if you got it at a sewing center ask them to demonstrate the machine so you'll know it sews.
Sep 10, 2011 | Singer Sewing Machines
Looking for bobbin case for singer 3270c I see lots that look like the one I have but none of the numbers they list match mine... Also the machine is bunching up the tread and my bobbin case is broke so...
check with these 2 websites for the part ,,
sewingpartsonline.com or sewvacdoctor.com
it's possible the bobbin case could be a problem, I have 2 sewing machine & if one of them had a broken bobbin case I would replace it
have you tried a new needle
also check the thread take up lever, if the thread comes off of it, that can jam up the machine as well, I've had that happen before
also keep under the needle plate area clean of lint or loose threads & also the bobbin area
Aug 14, 2011 | Singer 3270 Mechanical Sewing Machine
I purchased an older Singer Stylist zigzag model 457 sewing machine at a garage sale. It doesn't have the owners manual and the bottom thread gets all knotted up. It also is hard to feed the material...
I can definitely help you with the owners manual. Go to http://parts.singerco.com/IPinstManuals/457A_105_125_135_143A.pdf and you can download it direct from singer, no viruses, nothing. Just save it in Adobe format.
The bobbin thread problem is called a birds' nest and can be from a number of problems. First thing to do is to change your needle, especially if it was the one you bought the machine with. It may look perfectly straight to the naked eye. But it only needs to be a little bent to cause a problem. If this doesn't clear the problem up, make sure you're using a new bobbin, freshly wound. If the bobbin isn't wound properly or is an old bobbin that's slightly bent or not quite round, it'll cause problems, too. Finally, the machine may need a new bobbin casing. Do a google search for Singer sewing machine parts and search for a bobbin casing for a model 457. You'll remove the plate from the top of the machine CAREFULLY (the screws are small, so be careful not to lose them!). Take pictures if you need to with your cell phone so you can see what to do when you need to put the new casing in. Bobbin casings are usually $25-30. This is the last thing, and I would only do this if you see that thread is catching on something in the bobbin area when you're moving the wheel by hand.
I've tried to be clear on the last bit, but I realize it can be a little awkward. If you need any other help with that, please leave me a comment back. It goes straight to my email, so I'll see it quick and will get back to you right away. The manual doesn't help a lot with your bobbin problem, so I'll do whatever I can to help you through it and get you sewing. Good for you for finding a great garage sale find!
Jun 08, 2011 | Singer Sewing Machines
I just purchase a Singer 301 and cant get the bobbin case out
Raise the bed extension, revealing the bobbin area. Gently pull out on the bobbin case latch and it should pop right out in your hand. Congrats on your 301, they are wonderful machines!
Jun 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
100 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
