Question about Cfm Klimaire KSWG009H113 Split System Air Conditioner
Klimaire leaking water where cool air comes out
2 Suggested Answers
  • 13 Answers
SOURCE: Klimaire KSWG009H113 Split System Air...? system
check your filter if its really dirty it will decrease your air flow
Posted on Feb 07, 2010
What would make the unit come on then shut off over and over
does it cool when it comes on and how long does it run before it turns off?
Jun 28, 2014 | Klimaire Heating & Cooling
Fan will only blow on low when heat is on
your fan most likely is wired for low speed for heat which is common. this should be determined when furnace is set up properly. motors that aren't modulating motors and are multispeed motors typically have low medium and high taps that come off the motor and go to the corresponding relay on the board. low and medium speeds are used for heat and high and medium speeds are used for cooling. but only one speed for heat and one speed for cooling many times medium never gets used. im not familiar with klimaire is this a mini split system and not a regular air handler. cause speed control should be adjustable from the remote. if its a split but if not reaching desired speed due to a malfunction in the units could cause it to run low speed just to maintain the temperature exiting the indoor unit.
Oct 21, 2013 | Klimaire Heating & Cooling
I keep getting a p5 error code on the indoor unit of my klimaire minisplit
I have a 3 unit split.
I found out that you can not have one unit set to warm and the other to cold. The compressor doesn't understand it.
Cycle off on and quickly re mode to Cool .
Do it to each unit and you will get it to stay on and then you can adjust.
Took a while for me but it did stay on after switching Mode at startup
Jul 12, 2011 | Cfm Klimaire KSWG009H113 Split System Air...
I have a Klimaire 1200 btu heat pump split system brand new I installed myself (this is the third one I have installed). It worked fine for a couple of weeks and then the outside unit began to cut off...
Often on those types of units they use a sensor to sense the temperature of the return line to prevent liquid floodback...
I am thinking the either there is a shot of really sold coming back soon after startup or that the sensor is bad and is being too sensitive, shutting the unit down when it really does not have too...after it does this once it is more stable and it does not happen again til the end of the cycle...
Actually I think that it may be overcharged and theat is what is causing the problem...
Do you have a very short line set on thsi unit??
Was it setup with a precharged unit and lineset??? or did you build the lineset and then charge it your self???
heatman101
Dec 08, 2010 | SNK Klimaire KSWG012H113 Split System Air...
I just installed a Klimaire KSWG009-C113. It cycles on and off approx. every 3 minutes. Line set vertical drop is 20 ft, total is 25 ft suction pressure is 115 to 125 psi indoor temp is 32 degrees...
did you open both service valves? If it's 89 degrees F in your home you are WAY under charged, assuming you are using r410. what is the pressure when the machine cuts off?
Dec 30, 2017 | Cfm Klimaire KSWG009H113 Split System Air...
We have 10 hp Motor with centrifugal fan fitted with 5 TR Cooling compressor? We want to know the cfm of air?.
You need to either get the specifications from the fan manufacturer, or take air readings with a manometer or flow hood
Apr 27, 2010 | Cfm Klimaire KSWG009H113 Split System Air...
My unit was'nt cooling the room like it use to and then this morning it was leaking water in the room
Hi, it sounds like the evaporator coil that is located on the inside as built up with ice, and has blocked most of the air flow. What can cause this is a very dirty filter, indoor coil that's iced up, and if the filter and coil are clean, make sure the indoor blower is up to speed. Turn it off and let it defrost. It will take some time. Turn it on fan only. If all is clean and motor is fine and it continues to ice, you are low on freon, and have a small leak causing it to ice up. It is probably a very small leak that may have taken a few years to leak to this point. I would make sure the filter is clean, coil indoors is clean, and blower is up to speed. If this is all good, you will need to get it charged. This unit holds less then 2 pounds of R-22.
Keep me posted on the out come. You can pull the indoor cover and see if you have ice on it. Let me know.
Shastalaker7
Apr 20, 2010 | Cfm Klimaire KSWG009H113 Split System Air...
Feb 07, 2010 | Cfm Klimaire KSWG009H113 Split System Air...
Cfm Klimaire KSWG009H113 Split System Air Conditioner Logo
50 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
