Question about AcerPower 2000-UD431C - Core 2 Duo E4300 1.8 GHz (S6463626) PC Desktop
Acer Power 2000 Problem
I have two Acer Power 2000 UD431C. When power on, there is nothing in the screen for two computers.
Solution please :(
  • a1anm Feb 12, 2009
    I have this exact same problem. When I hit the power button the cdrom light flashes for about half a second and then nothing. Completely dead again.
  • Anonymous Mar 30, 2009
    YEP - SAME HERE
    Genius:
  • 2,785 Answers
Plz try by resiting the ram
Posted on Jan 13, 2009
Wifi modem is not recognized
Try recycling the wireless router by unplugging the power to it and wait 20 seconds then plug the router back in. Sometimes that is all it takes.
After recycling the router if the adapter still does not show any wireless networks make sure you don't have the wireless radio turned off in the software that runs the adapter.
If all fails, try the adapter in another usb port if it is a usb adapter.
You could reinstall the adapter's software and driver.
May 06, 2012 | AcerPower 2000-UD431C - Core 2 Duo E4300...
I have acer power2000 and the fan very noisy
There could be a setting in your BIOS , called " FAN SPEED CONTROL "
Turn this on, and it will go slower, so less noisy.
Jun 21, 2011 | AcerPower 2000-UD431C - Core 2 Duo E4300...
PROBLEM
What type of problem???????????
Jan 12, 2011 | AcerPower 2000-UD431C - Core 2 Duo E4300...
I have acer power 2000 dekstop computer,why my computer after 20 minutes of usage directly monitor suddenly blank? is there anything that can help me
it's probably in sleep mode. go into the control panel and try adjusting the power options so that it never goes to sleep.
May 08, 2010 | AcerPower 2000-UD431C - Core 2 Duo E4300...
I have a AcerPower 2000 desktop computer, when plugged in the fans run but I am unable to start the computer, no other lights are on.
Hi fspade
If you're lucky this could be very simple:
- Unplug the power from the back of the unit.
- Press the power button a couple of times.
- Wait 10 seconds.
- Plug the power back in and try and turn on.
If the above doesn't work then most likely there is an internal part failure (normally the power unit). I would take it somewhere to get checked out.
Hope this helps
Scott.
Feb 01, 2010 | AcerPower 2000-UD431C - Core 2 Duo E4300...
No display machine goes into Power Save Mode
Not much to go on here.
I assume you mean the machine goes into power save mode and you can't get it back out again?
There are power mode setting in control panel.
You might need to turn it off so the power save feature is not activated.
There are also power save setting in the BIOS settings.
Again you may need to disable it or try different settings.
Sep 20, 2009 | AcerPower 2000-UD431C - Core 2 Duo E4300...
My acer aspire one would not boot it would make it
Did you try to start it with the battery removed from the pc?
Jul 21, 2009 | Acer Aspire One PC Notebook
I ran a driver scan on my ACER Power2000 and the results said one of my drivers was out of date. (Unfortunately I didn't note which one it was, except that it was an Intel.) So I downloaded and installed...
Hey
Ok, the resolution the computer is using now is out of the range that is supported, try another monitor or try pressing F8 on the startup to get the advanced startup menu then select safe mode, in safe mode uninstall the driver you installed, this should return it to normal, then restart the computer and in normal mode you will need to install the old driver to get everything back to normal.
Dec 04, 2008 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Can't get screen display
AcerPower 2000-UD431C - Core 2 Duo E4300 1.8 GHz (S6463626) PC Desktop Logo
393 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
