Question about Apple Cinema Display 23" HD Monitor
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
Older M8536 (2002) monitor. Power adapter 3 years old.
    Master:
  • Apple Master
  • 545 Answers
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Posted on Dec 12, 2012
  • michael21473
    michael21473 Jan 26, 2013
    I think you missed the key word? 2002 there where no power supply on the 2002-2006
  • michael21473
    key word 2002 ? there where no power supply on cinema screens back then?
2 Suggested Answers
SOURCE: Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Posted on Oct 31, 2008
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Aple HD Cinema Display 23" is dead, no front LED light or back display light
Contact Apple support by phone 1 (800) 204-4427 US toll-free or chat, set up a repair, or make a Genius Bar appointment for iPhone, iPad Apple Mac Technical Support Phone Number 1 800 204 4427
Jun 14, 2017 | Apple Cinema Display 23" HD Monitor
After a couple of electrical power outages my Cinema 20" Apple monitor doesn't work. The power light (lower right) goes through cycles of off, dim, bright, etc. sort of as if it's flashing a Morse...
There are three "morse code" flashes that an Apple Cinema display can produce that are diagnostic:
Three short flashes (morse "s") means incompatible video format. Try resetting the parameter RAM when restarting to go to the default
Short-long-short (morse "r") means "wrong power adapter." I've seen some monitors that will not work with an adapter that others will and that give this signal. In some cases this can be fixed by insulating the power sensing pin on the display power cord.
Finally morse "u" (short-short-long) means a backlight problem.
May 19, 2017 | Apple Cinema 20" LCD Monitor
Apple Cinema HD Display 30'' black screen, power light blinking
I don't know what might have happened, but a number of years ago I had an apple monitor and the power light on it started blinking, so I got in touch with apple and they told me that it's flashing an error code, so they told me what the blinking indicated and fixed it.
So I think the blinking of the power light on your monitor could be indicating an error code so I suggest you call apple and they will identify what the error is indicating.
Feb 11, 2010 | Apple Cinema HD 30" LCD Monitor
Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
***CAVEAT AND WARNING***
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Jul 19, 2009 | Apple Cinema Display 23" HD Monitor
Apple 23" HD display screen is black, power is on... All wires are connected. The computer is booting up fine. The monitor light is on. The monitor is remaining black. This has never happened before. Any...
you need to open it up and replace the backlight(s), you will be quoted nearly the price new to get this fixed. might aswell bin it or eBay it! you intrestedin selling it?
Jan 06, 2009 | Apple Cinema Display 23" HD Monitor
Oct 28, 2008 | Apple Cinema Display 23" HD Monitor
Blank screen (Apple Cinema HD 23"LCD)
damn gay i got t is 23 apple screen for 14month and it has a black screen now :( .. what can i do to fix this .?
Jun 06, 2008 | Apple Cinema HD 23" LCD Monitor
Apple Studio Display Flashing Power Button
For the brave of heart, You can disassemble the monitor. After you get in to the inside of it, you'll see a circuit panel with 6 ballast coils on it. On my Cinema display, what happened was that the solder joints on some of those coils had cracked, causing intermittent connection. After hitting all the connections with a soldering iron to heal the cold solder joints and re-assembling it, it is working perfectly fine now.
Jan 29, 2007 | Apple Cinema HD 23" LCD Monitor
Apple Cinema Display 23" HD Monitor Logo
450 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
