Ventless gas heater won't stay lit.
My gas vent-less wall heater will not stay lit.
Accurate Joe
  • 61 Answers
SOURCE: pilot light does not flow gas
Change your theromcouple
Posted on Nov 29, 2008
SOURCE: wont stay lit
If the pilot flame does not touch the thermocouple, the heater will do exactly what you describe.
Get a short piece of copper tubing that will fit snugly over the thermocouple and bend the short piece so that it is in the pilot flame.
Posted on Oct 02, 2009
wcrawf11
  • 52 Answers
SOURCE: I have a Martin ventless gas log fireplace heater
You should the value there should be a pilot ajustment screw
some times it is hidden under another screw but should be close to where the pilot light line hooks to the gas value
Posted on Dec 12, 2009
SOURCE: warm morning propane heater. new thermal couple.
There are basically three things that can go wrong with the Warm Morning .
Sensor shut off. There is a sensor button on the back of the unit with a wire going from it to the thermocouple. This sensor turns the heater off if the flue is blocked, however it will also shut the heater off if the wire contacts are dirty, or if the sensor has gone bad.
You can test this by bypassing the sensor. Disconnect the two wires from the sensor and reconnect them directly together. If the pilot stays on, your problem is here. Try cleaning the wire contacts first.
Pilot orifice. If the pilot flame is small and doesnt look healthy, the pilot orifice may need cleaning. The hole is very small and can get dirty. Disconnect the silver tube and clean with electrical parts cleaner. Never try to clean the hole with an object like a pin, you may damage it. You may have to slide out the burner unit to get at the silver tube. (Always shut off gas before disconnecting lines and after you reassemble, spray joints with soapywater and look for small bubbles which may indicate a gas leak. Dont use parts cleaner around an open flame.)
Thermocouple can go bad but this is not as common as the first two problems.
Posted on Jan 28, 2010
  • 30 Answers
SOURCE: ventless gas wall heater. Pilot lights but wont stay lit.
The thermocouple may be worn out.
The thermocouple may have come loose from the valve.
The ODS pilot may be clogged with dust or lint and may need to be cleaned with air(less than 30psi)
The valve or regulator may be faulty.
Posted on Mar 04, 2010
My heater won't stay lit. Will light but after 10 or so seconds it clicks off pilot and all.
what type of heater? propane, natural gas, ? water heater, wall heater,?
If it is some type of gas heater, it sounds like u may have an unsafe venting condition. There aree safety controls that will make the heaters pilots go out in the event of a blocked vent. unfortunetly with the info u have posted i do not have much info for u either
Oct 22, 2016 | Heating & Cooling
Pilot light wont stay lit.
if you can re light unit all parts are good. if vented into a chimney or vent less than 3 feet out of roof can cause this.
Jan 07, 2014 | Cozy Enclosed Front Console Heater 70,000...
Hello i have a williams wall Furnace model#25-35-50. I need to know if its a base board heat and also if you could tell me which wires are which. 1 red and 1 white
What you have is a Direct Vent, Gas WALL Heater. It is normally mounted about 6" off the floor on an exterior wall (since it has to be direct vented out). Not sure what the red and white wires are for, but suspect it's for the optional thermostatically controlled blower connection.
In any event, to help you install this heater properly, I have included a link to the Owner/Installation Manual, which should provide all the information you need to complete the installation correctly.
http://shopfnc.com/pdffiles/williams2man.pdf
You can download and print the manual for future reference.
Feb 26, 2011 | Williams 3003622 Ceramic Wall Mounted...
Pilot light will stay lit as long as i hold down the knob, but when knob released, light goes out....... i have a wall mount model# GWRN30t
Normally when you release the knob it work the same as a two way switch ,which mean gas will stop flowing through the small pilot channel and will flow to large channel where it will continue to burn.
In your case, you have to strip down the regulator switch and look where the gas passage is glogged.
Oct 05, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Pilot light will not stay lit on model 465FX-R wall mounted gas furnace. Thermocouple was replaced but still won't stay lit. Gas is on at the meter. Any suggestions?
It is possible that gas valve is bad, however, try replacing the pilot orifice located in the pilot assembly. If the flame is inadequate it will not generate the voltage required in the thermocouple. Pilot orifices are less than $10 and can be found at your local heating contractor's parts counter. Bring in the orifice to match.
Oct 03, 2009 | Heating & Cooling
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
276 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
