Question about Refrigerators
My GE refrigerator model # gss25wtss. The top half of the freezer and refrigerator isn't getting as cold as they should. I also don't here the fans running either. Can someone help. Thank you.
  • 3 Answers
My mother had a problem of the circulation fan freezing up, therefore not keeping things cool in her mini fridge. When I went to visit her, she asked me to take a look at it. When I opened the door, I found it stuffed full and she was right, it was not cooling. So, I began emptying everything out to find that she had inadvertently blocked the circulation vents with packages of hamburger buns. After allowing the fan to thaw out, I turned it back on and reloaded it, being careful not to block the vents again. Checked it later and found it working fine. Remember, fixing the symptom isn't always fixing the cause! Hope this helps, if not, at least you know one thing to check if you have a similar problem.
Posted on Dec 11, 2012
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
  • 958 Answers
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
tborn6
  • 700 Answers
SOURCE: GE Model GSH22JFTA Top of Fridg and Freezer not cold
check the door gaskets for air leakage
Posted on May 21, 2009
  • 97 Answers
SOURCE: GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Posted on Jun 10, 2009
What is the model number listed inside the frig section?
Jun 29, 2013 | Kenmore 53642 / 53644 Side by Side...
Top half of my refrigerator and freezer not as cold as it should be
Make sure there isn't anything blocking the cooling coils GE Side by Side Refrigerator GSS25JFMC Service Manual in PDF format... You can purchase a service manual from here.
Jun 26, 2017 | GE Refrigerators
GE refrigerator isn't cold at all
you need to have the frig defrost the passage is in the back going from the frig to the freezer so if it is frosted in the back than the air is not moving correctly
Sep 18, 2012 | GE Refrigerators
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
It seems that the wiring diagram show the hot/black side going to the defrost timer AFTER the cold control/thermostat. how does the timer keep running when the cold control isn't...
If your model is the PSS26MSRSS the defrost timer is built into the motherboard and will be completely electronic. Click here for the=> Service Manual And then click here for=> GE Profile/Artica Technical Information Now it is possible that the model listed here requesting a solution may have been listed incorrectly by auto generated model numbers and not by your fault, it just happens here at times. So if this is what happened then try again to provide a different model number. Here is how GE locates their model numbers, Click Here=>
GE APPLIANCE MODEL NUMBER LOCATOR'S
Refrigerators
Freezers
  • Chest Freezer
  • Upright Freezer
  • Either way I am here to help and if your model is the model listed you most likely are having problems with either the compressor start components or the motherboard itself. If you would like me to assist you more just let me know HERE or here on Fixya. Seems lately customers are having a little trouble navigating the site due to so many new changes. Hope this helps, so let me know, Thanks, Sea Breeze
Sep 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile counter depth French door refrigerator bottom freezer and I keep getting frost in the freezer. The seal on the door isn't as tight as the seal on the refrigerator but no cold air...
Where are you getting frost at? Is it on the back wall in the freezer? if so - your problem may be a defrost issue and in that case you would need to hire a professional appliance repair technician to service your refrigerator.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
Aug 29, 2011 | GE Profile PDS20SFSR Bottom Freezer...
Top not cooling-bottom frezzer working ge model pds22sbnbs
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | GE Refrigerators
I have a GE Model GSS22SGRF refrigerator. The freezer is cold but the freezer isn't staying cold. Any suggestions?
heatman101
May 23, 2011 | GE Refrigerators
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
