Question about RCA 20V500T 20" TV
MY RCA TTE 20V500T TELEVISION IS STUCK IN CHILD SAFETY AND TURNED OFF W/NO REMOTE TO ACCESS THE MENU
WHEN I WAS TURNING OFF THE TV I INADVERTANTLY PRESSED MENU AND THE CHILD SAFETY LOCK COMMAND BEFORE SHUTTING DOWN AND NOW THE FRONT BUTTONS ARE DISABLED. I DO NOT HAVE A REMOTE FOR THE TV. IS THERE ANOTHER WAY TO TURN ON MY TV. i WAS RIGHT IN THE MIDDLE OF THE BRONCO/RAIDERS GAME. SO PLEASE HELP ME
  • RCA Master
  • 6,694 Answers
Without remote its not possible to disable child lock. If it possible to arrange the remote then you can do the following to override the lock.
1.Press VOL+ on the remote and CHANNEL + on the
front of the TV at the same time. Enter New Pwd.
will appear on the screen. (You must be in the Enter
password screen when attempting this).
2.Press the number buttons to enter a four-digit code.
The code will appear on the screen as you enter it.
3.Press OK to save the code.
4.Press MENU repeatedly to exit the menu or the menu
will automatically disappear within a few seconds if
no buttons are pressed on the remote control
Posted on Dec 16, 2012
MikeNJ1964
  • 398 Answers
SOURCE: RCA 36 in. tv no volume
It is not a loose solder joint. It is not a faulty capacitor. Usually, a spray cleaner or some other fluid is sprayed or spilled onto the top or front of the TV and it seeps down inside and contaminates the little pushbuttons. If the volume down pushbutton is contaminated, the set will have the exact symptoms you are seeing.I have seen this many, many times, and once I saw a pushbutton contaminated with cigarette smoke. The pushbuttons should be checked and/or replaced by a qualified tech.
Posted on Sep 30, 2007
SOURCE: RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Posted on Jan 05, 2008
jerryg50
  • 1689 Answers
SOURCE: rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
Posted on May 25, 2008
SOURCE: I need to remove child lock (without remote)
hi did you get to solve your problem becuase i have the same problem
Posted on Jun 11, 2009
ladywinn
  • 5138 Answers
SOURCE: i need a universal remote code, rca 20v500t
000
Posted on Dec 24, 2009
RCA TV CHILD SAFETY MODE
Not a sure thing but I remember it being hold both vol up and channel up for several seconds to release the unit presuming it is actually locked.
Dec 10, 2012 | RCA 20V500T 20" TV
My child got the remote and now my volume's not working anymore. What do I do??
Check internal/external speaker switch on back of tv. Also try turning speakers on through consumer menu using remote.
Jan 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA model 20V500T television. There is an arcing noise coming from inside the back of the television. When this noise occurs a couple lines appear and disappear on the television screen. What...
High Voltage leak coming from anode button ,it nees to be resealed. TV contains around 20,000 volts up to 22,000 volts . Tube must be discharged in oder to correct problem .
Dec 27, 2010 | RCA 20V500T 20" TV
RCA 20V500T television. Inadvertently set FPA (parental control) to on. I shut TV off thinking it would reset. It is now in standby (in accordance with manual). It can only be turned on with remote. ...
Hello
You just try the following to open your TVs lock.
You must have its remote to unlock it.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Dec 23, 2010 | RCA 20V500T 20" TV
My rca tv reads function disabled when I push the menu button on the front of my tv. how can I enable it?
easy. some rca tv's have a disable function for the buttons on front of tv. keeps little children from changing channels and going into menu. you need a remote to access the menu. then go into parental child lock function in menu. hope you are not the child and your parents locked the front buttons. hehe
Nov 08, 2009 | RCA Televison & Video
Child lock on
Simply get a remote control....I have the same television. It is the only way. No bipasses available
May 31, 2008 | RCA TruFlat 27F520T 27" TV
RCA 27F520T child lock on without remote
go to menu and find the child lock and unlock it.
Televison & Video Logo
124 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
