Question about Kicker IX704 Car Audio Amplifier
IX704 I think that the rca are not so good, ther is a sound coming from the speakers when i step on the gas, I have the ground connectit to the chassis and 2 more amps to the same ground I am using 3 optima batteris to drive them. my system is rmb8 front with r5c in front with 2 silk tweeters in front with 6x9 in back and solox 18" in back, all kicker :) would it be best for me to buy new IX704 or let someone fix it ??
  • 883 Answers
You need an ignition noise filter available at radio shack. This electrical filter blocks "engine noise" to reaching your audio amp.
Posted on Jun 11, 2007
  • Marty marty Jul 17, 2007
    hey!
    your fix is to do what I suggested..."you need an ignition noise filter"...how was that not helpful?
I have no sound coming out of my speakers for the reciever that is hooked up to my tv. i have 2 of the spekers hooked up and the audio cable plugged in to the tv but im getting no sound from the tv t
hi,try going into your tv setting and see if thers a setting for ext speaker as sometime ther is ,this is the place i would look and the only place i would think the fault would be ,you say audio cable i take it you mean
rca cables [two cables] if not check them but i dont think its both of them faulty,def in setting somewere.good luck
Jan 21, 2013 | Kenwood Audio Players & Recorders
When I turn the volume control on my home powered subwoofer, it makes a humming sound, then it stop working
check your connections, RCA, Speaker wires, maybe there is grounded. try other wires which you think in good condition..
Aug 10, 2012 | JBL Audio Players & Recorders
Bought a hitron 3200b secondhand. installed the amp and no sound I have a 06 gmc I am using an aftermarket radio it is a lo line model made by I think dual 50 bucks at walmart all connections are good...
Bypass the amp with a small speaker or tweeter to make sure your rca input is working. Is the amp light on. Got good power, ground, and remote? Have you tried a different set of speakers on your amp?
Sep 04, 2011 | Hitron HA20002 Car Amp
No sound from speakers, but there is power to amp
make sure the power wire and the remote wire have voltage. at least 12 volts. make sure the ground wire is good and has a good solid ground. after that make sure the rca cables are getting signal from the radio. if you have a small speaker or tweeter you can touch the wires from the speaker to the rca cables and it should play music very quietly. meter the subs and make sure theyre ok and not shorted or bad. if all that checks out good.... the amp is probably bad. start with all the simple stuff and work youre way up. if the amp has good power and signal and good speakers then the only thing thats left is the amp. good luck
Dec 29, 2009 | MTX X702 Car Amp
MY SON'S RADIO ISN'T WORKING, ALTHOUGH IT TURNS ON . HE HOOKED UP SPEAKERS TO THER RADIO. DO YOU THINK IT FRIED OU THER RADIO?
no just not hooked up right. some cars have chassis ground speakers which can be a pain. best to let a pro do it and watch.
Nov 27, 2009 | 1998 Oldsmobile Regency
No sound coming from subs
You definitely NEED a source signal for the amplifier to amplify!
You should have a Main Power Wire, a Ground Wire, A Remote Turn on Wire, and RCA cables (or hi level speaker wires if your amplifier has them)
and the speaker wires to the subwoofers.
Thanks for using FixYA - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2009 | Kenwood Car Audio & Video
Humming sound to speakers from amplifier
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
Hope this helps
Mar 28, 2009 | MTX X Thunder 1000XD Car Amp
RCA Pre-Out Making Producing a Mumming and a Popping Sound.
the speakers hook to speaker wires not to any thing else no power no negative poles do you have a remote shut off switch connected to amp this would be important to cut off amp
when cut off amp if you still here the humming this can be an indicator of low power being produced by alternator alternators produce 14 anything below 12 would mean replacement of alternator
if alternator fine then you need to find new ground for amp and make sure you have a good ground for sterio this can be checked with a test light
to check a ground all you do is hook gator clip to power then touch test light end to ground on radio end light comes on got a good ground (make sure not to touch any other sterio wires just the ground wire while connected to power to check grounds)
if pulsing in test light on the ground means you have a bad ground
just disconnect move to better ground
check the amp ground the same way as decribed above
May 09, 2008 | Pioneer DEH-P3900MP CD Player
Weird sounds coming through speakers
The problem is not likely the amp. The length of the ground to the amp is not as critical as a good solid connection. Clean any paint and dirt from around the ground connection. It should be clean and shiny metal. Anyway as a test disconnect the RCA's from the amp while the amp is on and see if the sound goes away. If it does then the problem is not in the amp but either the RCA cables, the RCA grounds in the head unit (radio) or bad routing of the RCA cables. Depending on the how old the car is this noise can be coming from your spark plug wires as well. As a last resort you can try a new set of supressor ignition wires for the car.
Jul 13, 2007 | Rockford Fosgate Punch 401S Car Audio...
IX704 kicker
There's a pretty good chance that your speaker load is too much or else your power coming in is not sufficiant. Be sure to check BOTH the battery and ground connections to be sure they are supplying enough power. If your speaker load is too much then correct that at once before you fry your amp. Good luck.
Jun 06, 2007 | Kicker IX704 Car Audio Amplifier
Kicker IX704 Car Audio Amplifier Logo
78 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
