Question about Broan-NuTone Best by Broan 600 cfm External Blower - EB6 Kitchen Hood
I have a model EB6 best by broan range exhaust fan. When i turn on the fan it just humming sound. what do you think the problem is?
  • 7 Answers
SOURCE: range vent damper noise
Check to make sure that the installer completely untaped the damper when he installed it. It needs to be able to move freely.
Posted on Aug 24, 2009
  • 95 Answers
SOURCE: Broan range vent fan not working
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Posted on Sep 19, 2009
heatman101
  • 43501 Answers
SOURCE: Model 41.000-L range hood. Fan
Sometimes they can be cleaned and oiled and they will work again...
Cleaning the grease and dust with out ruining the motor is the tricky part...
Take the unit apart as much as possible...spray down the fan part with a degreaser or strong cleaner...let it soak and they spray it down with water to rinse it off...
Then work a few drops of light motor oil into the motor by proping up the fan so that the oil will run down the shaft and into the motor...
then get it running smoothly by working it by hand...
Put it all back together and it should work again...
heatman101
Posted on Jan 16, 2011
  • 1583 Answers
SOURCE: Broan Allure range hood fan
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
Posted on May 19, 2011
ekcnoel
  • 998 Answers
SOURCE: I have a Broan range
Sir try to check the starting capacitor and the ac supply feel free to send feed back good day and best regards.
Posted on Sep 13, 2011
Broan S130A bathroom exhaust fan loud hum
The start capacitor for the fan motor is defective.
Dec 12, 2013 | Broan-NuTone Dryers
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
My model 8663RP "B"-Unit Combination
It sounds like the fan blade may be loose on the motor shaft. You can purchase a new motor for this fan online.
Look here: http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/S97017705-Motor-Assembly-.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rp&Search.x=0&Search.y=0
May 02, 2011 | Broan-NuTone N-8663RP Combination Light...
It just hums, the fan does not turn.
Make sure the power is off before doing anything. the motor may be clogged with dust, clean it out really good with a blast of air (air can bought at radio shack) get a can of WD-40 and squirt a little on both bearing ends and turn the fan until it feels easy to rotate. make sure no one is near the fan when you turn it on because some of the WD-40 may splash all over. If this does not work you may have to order another motor. http://parts.broan-nutone.com/broan/Shop
Jan 03, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
My parents had a Broan exhaust fan installed in their bathroom and water is leaking from it. Any ideas on what this could be?
Sounds like a condisation problem. Check the exhaust tube for low spots, and also check if the exhaust tube is isulated.
Nov 29, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
www.broan.com
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
Kitchen Ranges Logo
27 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
