Question about VillaWare Mickey Mornin' 5555-11 2-Slice Toaster
With VillaWare Mickey Mornin' 5555-11 2-Slice Toaster won't play sound
I'm about to purchase this on ebay and the listing has it in great condition, but without sound. Is there anyone that knows how this works and possibly could help to repair it?
5 Suggested Answers
SOURCE: Expensive toaster doesn't work
I broke mine trying to fix this, but the fix is very easy. remove the out shell and you will see two prongs with contacts that engage when the plunger is pressed. The plunger will not stay down because the prongs are bent and/or dirty. clean the contact, push the prongs closer to the contact and that should do it. Becareful about how you disconnect and reconnect the wires. That is the mistake that I made, and the fuse blew. BTW, if you fix yours, please let me know what kind of fuse is on it. The fuse is in a sheet in a cluster of wires between the two plungers.
Posted on Feb 16, 2010
SOURCE: Villaware mornin toaster 5555-11 When you put the
When you push the slide down on the side, there's a wire that it pushes down inside the toaster. If the wire gets bent down a bit, pushing the slide down doesn't push the wire down enough. The wire is like a teeter totter. When it gets pushed down, it closes the circuit which turns the toaster on. The reason why the slide doesn't stay down is without energy, the electromagnet doesn't get engaged. That's what keeps the slide down. You need to remove the 4 screws on the bottom, and the 2 screws that hold the legs on that also hold the side on with the slide. Once the side is off, take a pair of needle nose pliers and bend the wire up a bit that acts as the teeter totter.
Posted on Apr 15, 2010
SOURCE: villaware toaster parts
dear cflanagan, my villaware toaster red switches are broken too. did you find replacements if so email me phillyeagl1@yahooo.com
Posted on Aug 03, 2010
ginko
  • 19396 Answers
SOURCE: mickey classic toaster 5555-07 toaster
Hi.
Villaware replacement parts are only distributed by Holmes Europe. To get the replacement heating element please call 0800 311 2198 (use 0044 if calling outside UK), or contact the Holmes service and parts distribution center at the direction below:
Holmes Products (Europe) Ltd.
1 Francis Grove
London, SW19 4DT
UNITED KINGDOM
enquiriesEurope@jardencs.com
You can also submit the request directly to Villaware. In that case call +44 (0) 20 8947 8272 or use the online contact form available at this page.
Regards.
Ginko
Posted on Aug 07, 2011
No image - polaroid comes out and stays black
Probably defective when listed on eBay
Mar 01, 2018 | Photography
Where can i get a replacement on board fan from?
fans are pretty standard things with only 2-3 different sizes so you wont have great difficulty getting one from your local friendly neighbourhood pc repair shop...or electronic retailer unless you live in the Australian Outback or Outer Mongolia or somewhere equally remote. Try a Tandy/ Radioshack/Maplins/PC World-you don't say what country you're in so can't 2nd guess what retailers are near you.
Don't forget, these things aren't motherboard specific; if it's your cpu chip fan then that's more specific to the cpu processor; try searching for that, and if it's just a motherboard cooling fan, then measure the length of one side in mm, and search for that size fan. The fan voltage is always 12volts.
Jun 11, 2012 | DFI LANParty UT RDX200 CF-DR Motherboard
Will anyone purchase a tv with a cracked screen for the inner parts?
not likely as if set was on or powered on later there may not be any usable parts---consider listing it on EBAY?
May 13, 2012 | Samsung PN51D430A3DXZA - PN51D430 51 720p...
How to get an old Alphie toy to work.
You're likely going to spend more to get your 18 year old toy to work than to purchase a new one. You can get a new Alphie with instructions, etc., at Amazon for $39.95 and a used one in excellent condition on eBay for $15. That's the way I'd go if I were you. The technology alone that has evolved since 1994 makes replacing vs. fixing the way to go. :)
Jan 03, 2012 | Hasbro Alphie The Learning Toy Robot
I purchased an item with collect later, but I don't know if the sale when though
sign in to ebay on the home page from the Ebay drop down list select purchase history you will see all items purchased for the month
hope it helps
Nov 27, 2011 | eBay Auctions
I bought a protable tv that doesn't work at all. Screen is black and there is power going to it. No volume either. Contacted seller's e mail to no avail....what recourse do I have?
If this purchase was through ebay, go to the ebay page under purchase history, and (under your purchase) contact seller to make them aware of the problem.
If you still don't hear from them (or have already done that) then under the same listing, click resolve a problem. It will contact seller for you and create a case (I am assuming this was listed as a working item) for item not as described. There is a link below for creating a case.
I would also recommend using the ebay learning center to go through the other policies when you make purchases on ebay.
http://contact.ebay.com/ws/eBayISAPI.dll?CustomerSupport
Sep 12, 2011 | PayPal Accounts
Hello There: I have an Acer Monitor in Canada. Will this also work in the Philippines re they are 220 voltage? Thanks David The Monitor is a AL1706
You'll likely have to use a power converter that will convert from 220 back down to 110 (along with the plug differences).
Here are two links to two different quality products that should work for you:
Kensington http://www.amazon.com/Kensington-33117-International-Travel-Adapter/dp/B0002H4YUI
Targus http://www.amazon.com/gp/offer-listing/B00004Y7M3/sr=/qid=/ref=olp_tab_new?ie=UTF8&coliid=&me=&qid=&sr=&seller=&colid=&condition=new
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 28, 2011 | Acer Computers & Internet
I have a emachine w3503 and my sound is dead
Hello sortugado, If your sound is dead, This could mean that you've plugged it into the wrong socket. This could be wrong. But try this.
Start - Control Panel - System - Hardware - Device Manager - Right Click on the Sound/Audio (it should have a yellow sign next to it) Then go Find Manually and go down the List, Press Sound & Hardware, What ever brand your computer is, there should be sound that is the brand name as the same computer brand you have. Once that's found, Click it. It should then install your hardware sound. If this problem still doesn't work, You can simply go on ebay and buy a $5 Sound card. These do work, I am using one now, and let me tell you, it's absolutely great! So cheap great quality, and fast shipment. I hope you get your sound to work :)
- Steven ASAP
Here to help!
Apr 24, 2011 | E-Machines W3503 PC Desktop
Where can I purchase a new temperature probe for my Aroma Grill AHG1125?
Hi, not sure if you are still looking for a replacement temperature probe for your health grill but we have just listed an Aroma Health Grill on eBay, Model AHG-1125. It is used but in great condition. Take a look at http://www.ebay.co.uk/itm/251106355119?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
The listing ends on Sunday 22nd July at 8:51pm. Cheers.
Dec 02, 2010 | Aroma Health Grill AHG1125
VillaWare Mickey Mornin' 5555-11 2-Slice Toaster Logo
53 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
