Question about KitchenAid Kitchen Ranges
Is the kgst307 3 prong plug for 110 or 220 current?
    President:
  • KitchenAid Master
  • 1,922 Answers
110 volt a.c.
Posted on Dec 11, 2012
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
Need to wire my 5hp compressor to a 11hp 5500 watts generater
I'm not sure what you mean by "wire my 5hp compressor to a 11hp 5500 watts generator?" The compressor should have a three prong plug-in cord from the pressure regulator and the generator should have a three prong outlet to plug it into. Do not try to wire the compressor directly to the power generator (dynamo), the current must go through the circuit board then to the outlet to make sure your compressor motor is getting the proper current.
Feb 21, 2012 | Coleman Air Tools & Compressors
How do you change a 4 prong dryer plug down to a 3 prong power plug
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
Sep 05, 2010 | Whirlpool LER5636P Electric Dryer
Trying to replace a 3prong plug with a 4prong plug
Ok, so you currently have a three prong cord on your dryer? Your house has a 4 prong receptacle? Ok so now you've purchased a 4 prong dryer pigtail? Be sure cord is unplugged. Remove cover of junction in back of dryer. You will see three terminals. They should be labeled something like L1,L2,N . ON one terminal you well see a small ground strip This is currently connecting the neutral terminal to ground. On the new cord connect the outside two conductors to L1 +L2 connect the white conductor to the N terminal. Connect the green (ground) conductor to the frame where the copper bonding was. This seperates the neutral conductor from the equipement grounding conductor.
Jul 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a 125/250 3 prong outlet but the current 3-prong plug on the maytag altantis dryer has an extra notch on one of the prongs. is there an adapter that i need to get to plug into my existing outlet?
The L shaped prong is for a 30 amp outlet and the 3 straight is for a oven and denotes a 50 amp circuit. Please use the proper connectors and wiring, Eric
Jun 15, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How many prongs are on amana NED5100TQ electric dryer? I have a new one being delivered today and currently have a 3 prong hookup
Generally you have to purchase the cord separate from the actual electric dryer. Therefore, call the company and tell them you have a 3 prong outlet, that way they can install a three prong plug. Many times, they bring both plugs with them and do the plug install on site. Enjoy your new dryer!
May 01, 2009 | Dryers
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
I need to change the power cord on our duet dryer from a 4 prong to a 3 prong The 3 prong does not have a neutral wire does that matter?
I think you need to read the following link to make sure you aren't violating any electrical codes, first:
Yes, a 3-prong DOES have a NEUTRAL wire. That would be the WHITE terminal. A 3-prong does not have a separate ground. The NEUTRAL is usually grounded at the appliance casing by a jumper wire.
Read in the "Additional Notes" section on how to convert from a 4-prong to 3-prong. Also note that some of the newer appliances require a 4-prong plug in order to run correctly. I have a Kenmore HE3 model dryer that is currently using a 3-prong power cord. Since this model Kenmore is manufactured by Whirlpool, and is identical to the Duet, you should be okay with a 3-prong plug.
Aug 08, 2008 | Dryers
Open Questions:
Kitchen Ranges Logo
259 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
