Question about Navman Tracker 5500i GPS Receiver
Navman Tracker 5500
This unit cann no longer find a GPS Signal. This problem started some time ago but now is permanent Can you help
    New Friend:
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Posted on Oct 30, 2013
SOURCE: Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Posted on May 02, 2008
SOURCE: Navman Tracker 5500 Marine Chartplotter
Yes the screen is replaceable, there are four screws holding it to the PCB and a short ribon and a two wire power lead.
Posted on Oct 21, 2008
SOURCE: navman gps tracker 5110i . lost the operation manual
Look Here....
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5500_5100/5500_5100_eng_web.pdf
Mark
Posted on Dec 17, 2008
  • 16 Answers
SOURCE: navman tracker 5100i keep loosing gps signal and
NAVMAN F10 WILL NOT ACQURE GPS SIGNAL EVEN AFTER RESETTING
Posted on Nov 24, 2009
SOURCE: i have navman tracker 5500 gps and the gps signal
I HAVE THE SAME PROBLEM.U WILL FIND THE ANTENNA IS BUGGERED.THERE ARE NO SPARE PARTS AVAILABLE FOR THIS MODEL.LESSON; DON'T BUY NAVMAN OR NORTHSTAR.I HAVE ONE OF EACH. NEVER AGAIN!!!
Posted on Jan 18, 2010
Dear Sir.I would like to know that the availability of navman tracker 5505,5605 or 5507. I am ver interested to place an online order for the Tracker 5505.thank you. Ahmed Rasheed.Maldives, e mail. ah
The NAVMAN trackers are no longer available as the company stopped making marine products. You can however find current products at www.lowrance.com.
The closest you can find is a Lowrance Elite 5mHD
http://www.chsmith.com.au/Products/Lowrance-Elite-5m-HD-Chartplotter.html
In case you want to refer to a manual for 5505/06 refer this site.
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/Tracker5505_5605/English_T5505_5605_manual.pdf
You can still find some old 5505 units at speciality marine online stores. Give this a try.
Northstar Navman TRACKER 5505
Aug 04, 2014 | Navman GPS
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
Slow at finding satelites
Most common reasons for this is that your battery level is low. Make sure it is fully charged before use.
Please rate my help++++Thanks for using FIXYA
Jan 12, 2010 | Navman Tracker 5500i GPS Receiver
I have navman tracker 5500 gps and the gps signal not working so there is no signel but all the charter is there
Nov 17, 2009 | Navman Tracker 5500i GPS Receiver
Navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
Aug 11, 2008 | Navman Tracker 5500i GPS Receiver
Navman 5500 tracker
Apr 24, 2008 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500 turns on but locks itself in the entry page
Have the same problem??
Used to take less than a minute to acquire satellites now takes 10-20minutes.
Nov 08, 2007 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500i GPS Receiver Logo
371 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
