Question about Sewing Machines
My brenina looses power every few min
Turns off
  • Sewing Machines Master
  • 7,365 Answers
The problem could be with the power cord, or the plug thats the
power cord plugges into or the motherboard, so the wiring
it would be a good idea to have the machine checked
Posted on Dec 11, 2012
Has the fuse blown on my machine? It doesn't turn on anymore. I changed the bulb and accidentally put in a 25W instead of a max 15W and it turned on for a few mins until i started sewing and it cut.
Hello Jess
Your manual is listed below, but I don't see a fuse or a reset button at a quick glance.
However, open up the area where the bulb is and look for a reset button. Also look on the foot pedal. Plug something else into the wall outlet to verify that a breaker hasn't tripped.
Did the machine work with no bulb alight? Wondering if the bulb must be working and present for the machine to function for safety reasons?
You know there is an On/Off switch above the power cord on the back of the machine, PAGE 6, Figure 1 in the manual?
http://www.singerco.com/uploads/download/38b237687d4dcaa62be10a78bb352508437b5509.pdf
Jul 02, 2016 | Singer 2250 Tradition
How do I fix the tension - it is too loose and knots up after a few inches
The tension disc is turned to the right to tighten, if the stitch on the top of fabric is loose then the bobbin is your problem
Mar 07, 2015 | Sewing Machines
Bernina artista 165 has always worked perfectly. Ran last night. I turned it off. When I tryed to turn it on today there was no power - checked all cords and outlets. After looking it over for 30 min. I...
Apparently,where power cord comes into housing /stress relief has worked loose.If cord is user serviceable(probably not) UNPLUG UNIT while servicing.Might be as simple as interior stress relief has worked loose,but again,unplug unit while tightening this.Are you using a foot treadle?? also,power cord itself may be bad.
May 09, 2017 | Sewing Machines
Babylock bl3 437
What are you sewing? Might be way too heavy to sew on this little machine.
Motor is failing if heavy use motor is dying or voltage regulator inside machine is gone bad.
Apr 19, 2014 | Sewing Machines
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Sewwing mashine sudenlly just turned off
if you have tried unplugging and letting it set for a few mins and plugging it back in... and still have no joy... it is likely that a short or something blew a fuse. I would take the machine in and have them do a check, clean and adjust while they did the repair.
Jan 14, 2013 | Sewing Machines
My bernina artista 165 turns off and then back on in the middle of my sewing
could be a short in the wiring , it may not be getting a good
connecting from the power cord,or the motherboard could be
going out
Dec 10, 2012 | Sewing Machines
My machine keeps freezing on me. It will work if I leave it off for about 10 min. but only for a few min. and then stops working again. I have to turn it off for 10 min. again before it works...
If the handwheel is tight and difficult to turn, then there is a bind somewhere. Could be debris in the hook raceway, thread caught in the take-up crank or a shaft bushing failure. Consult your instruction book for directions on how to clean out the hook area. If cleaning the hook area doesn't help, take it to your repair person. The more you use it in this condition, the worse it could become.
Jul 14, 2011 | Bernina Activa 140
Mu Juki machine with a Sc-800 control just beeps a few times when it turns on but wont run. I pulled a cover off the front of the sc-800 control box and saw E 0001 displayed inside... Any suggestions...
hi there
E0001 means:
1 - power plug or plug socket loose re plug securly
2 - power switch terminal is loosed or removed
3 - contact of power plug wection is not good correct the plug socket
best regards
ashraf abozid
aabozid@hotmail.com
Sep 15, 2010 | Sewing Machines
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
