Question about Sony Walkman NWZ-S616F MP3 Player
Sony NWZ453F problem it wont charge saya its full i unplug it says its empty have reset on the back and everything pls help
  • 3 Answers
Hi, I had the same problem. I have an old computer, so I tried it on my daughter's laptop and it started charging. I bought a Music Power dual port USB AC Charger at Walmart for about $15, plugged it into the wall, and it is charging away. I hope this will solve my problem.
I think my computer just wasn't compatible enough to actually charge it. Hope this helps!
Posted on Jan 15, 2009
  • jo6608 Jan 15, 2009
    OK, well it charged for a couple of hours before it said it was full, and now it seems to be working fine (so far).
My galaxy tab :- just bopught for 2 mths. Charge full at night and the next day evening battery totally 0%. I havent got any chance to play with it yet. i charge it full again and this time I thought...
Hello Sir !! I am afraid to tell that your battery might be got damaged by over charging.Electronic devices must be unplugged when the icon comes "Battery is Full" or like wise.Over charging damages the efficiency and produces extra heat that reduces the strength of charged battery.I suggest you to unplug the tab as soon as it got charged.It might increase your battery timings. If this information was helpful please rate or token of appreciation will be esteemed.
Mar 29, 2011 | Samsung Tablets & eReaders
Power on lensa tidak mau keluar.muncul tulisan turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN ditampilkan pada layar LCD saat Mekanisme Lensa macet atau ketika terpengaruh oleh kerusakan apapun. Jika memutar power on dan off lagi tidak menyelesaikan pesan kesalahan, coba lakukan reset kekuasaan dan Inisialisasi pilihan.
Melakukan reset tenaga manual
Matikan kamera.
Keluarkan baterai.
Tekan terus tombol daya selama 30 detik.
Biarkan kamera untuk tetap tanpa listrik selama 60 detik.
Masukkan kembali baterai.
Hidupkan kamera.
Untuk mengatur ulang Kamera kembali ke default pabrik, pilih Opsi Initialize dari Menu Utama Pengaturan 1 dari Kamera ke OK.This akan mengatur pengguna menentukan pengaturan kembali ke default pabrik. Gambar-gambar dan video tidak akan bisa dihapus.
Jika masalah berlanjut, mungkin diperlukan layanan.
Terima kasih telah menghubungi FixYa.
Feb 23, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Sony Walkman NWZ45F says its full
I posted in another thread about this same problem. I used a Music Power AC adaptor from Wal
Mart and it charged for several hours, and now seems to work fine.
Jan 13, 2009 | Sony Walkman NWZ-S616F MP3 Player
Disk Reading
Well try resetting the outlet that the PS3 is plugged into, unplugging everything from the PS3, and plug everything back in, it should work. If not, call Sony Customer Support and they will Fix your PS3 For you. Hope this helped.
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Humidifier says "bucket full", not using bucket have hose attached
Offhand, two possibilities:
1. erroneous sensor reading(s) causing system to respond likewise erroneously; and/or
2. firmware/software glitch.
Initially, I would suggest a full hard reset, that is unplug from the mains for an hour or so. This would normally revert the unit back to factory default (assuming no hardware problem). Additionally, you may want to check the sensor(s) like the a bucket full sensor often would be a float switch of some kind.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 09, 2008 | Goldstar DH504EL Dehumidifier
No power
It is possible that during your absence, there was a power outage/interruption, a thunderstorm or even a spike in the power lines.
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (a couple of hours).
Other than the above, there is no other user action possible as the unit has to be opened requiring knowledge with electronic components and circuitry. If the full reset is still a no go, then perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Good luck and kind regards.
May 12, 2008 | Sony MHC-RG660 CD Shelf System
How to format the nokia 5300 phone memory
just remove your MMC n just type *#7370# n will ask u the security code.type it out (default code is 12345 )
NOTE: battery must b full, else if format is disrupted by low batt, consequences will b disastrous
I heard the code *#7780# works too, pretty much the same i think.
but back up everything before doing this onto ur computer or MMC.. dont forget to rate me.. thank you sir
May 11, 2008 | Nokia 5200 Cellular Phone
Sony Walkman NWZ-S616F MP3 Player Logo
110 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
