Question about Refrigerators
Subzero drawer jammed - Refrigerators
  • 3 Answers
After viewing the video a few times, it appears that the drawer is off the roller track. Notice the roller at the bottom right corner side, I think the lip of the drawer should be on the outside. There may also be a track or rail the roller fits in. Try lifting the rear of the drawer at the rear and angling it over the rollers and pulling the whole thing out. Then just look at how it fits together, then reline the rollers with the track, then push it back in. good luck!
Posted on Dec 11, 2012
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
The top shelf of the crisper drawer on my Subzero 650/0 is rusting. Do you need to replace the entire crisper drawer?
No, but you will have to replace that entire glass shelf, as it is not sold in pieces. there is a rubber seal on the back of it that slides out. That may not come with it and you may have to transfer it over. Good Luck!
Sep 12, 2013 | Sub-Zero Refrigerators
Sub zero freezer drawer frozen shut
Subzero freezer: We had all our drawers stuck, including the ice drawer. We turned off the refrigerator, took all the drawers out and defrosted the rails with a hair dryer. The ice drawer was misaligned, so we reset the allen screws on the left to be the correct width. All better!
Sep 08, 2012 | Refrigerators
Subzero 650 bottom freezer is pooling water under the veggie drawer
Check you your drain line behind the 2 bottom drawers. Most likely it's clogged. You can try snaking it out with a single foot wire. See if the water goes away from the trough.
Smith Brother Appliance Repair reviews
Apr 12, 2011 | Sub-Zero 650 / O Bottom Freezer...
About once a month my subzero refrigerator drawer (700 series) gets a significant amount of condensation on the underside of the bottom drawer. its enough water that it is puddling on the floor below and...
the condensation is caused by fresh vegetables and uncovered food,and of course opening the door,now you cant do anything about opening the door but.....(i put a kitchen tissue under the drawer for this very reason and change it every 5 days.)
Sep 11, 2010 | Refrigerators
Need drawer bins for a Subzero 201R refridgerator 30 years old
There may be a serial number break that would give a different part number. Make sure you give the serial number to the people you order parts from and see if they get diferent part numbers.
Jun 27, 2009 | Sub-Zero Bottom Freezer Refrigerator
I have an older model subzero (refrigerator on top and a single drawer freezer on the bottom) which, when the bottom drawer is opened, leaks water. What to do?
Honestly I can't think of any cause for this that wouldn't require a qualified servicer. Most likey one of the drains is blocked and they make heaters to correct the issue
Jun 09, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Oct 16, 2008 | Sub-Zero Refrigerators
Subzero model 532
Fernando is right! Now I will put it in girl terms. The lip of the drawer (lip is at back of the drawer) rests on a white plastic thing. But when you take the drawer out completely, the white plastic thing retracts and just looks like the back of the fridge. So when you go to put the drawer back in, you see nothing to put the lip on. So pull the white plastic thing (it looks like a white plastic rectangle about the size of an envelope) forward and then hook the lip onto it and gently pull the white "augur" (the thing that senses when it's time to make ice) down and slide the drawer back in. My son figured this out from reading Fernando's solution. What a relief! Our model is a 561.
Nov 03, 2007 | Sub-Zero 632 / S
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
