The clock continues to blink and will not reset on yorx r5285
The clock will not stop blinking but continues to keep time and will not reset.
the dr
  • 447 Answers
SOURCE: whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Posted on Dec 23, 2007
meshif
  • 81 Answers
SOURCE: Internet Light keeps blinking - all others are out - No internet
A flashing internet light(all others off) indicates that the modem is searching for a signal from your ISP. Try rebooting the modem and if that doesnt do it replace the coax going to the modem. If you still dont have internet then go ahead and call your ISP as it could be a problem on their end.
@CluelessNYC: If you purchased a modem from a third party then you may need to register the MAC address with your ISP. Most cable providers tie your account to a specific MAC.
http://www.simplehelp.net/2006/08/01/cable-modem-troubleshooting-rca-dcm325/
Posted on Jan 24, 2009
  • 55 Answers
SOURCE: Smart UPS 1500 - battery level green lights blink on and off
You need to run recalibration on the unit.  The supplied PowerChute software & cable will allow you to do this if you hook the UPS up to a PC (I know it works with the serial cable, not sure about USB).  If you only have a MAC then I cannot offer a solution other than to buy the standalone PowerView device from APC.  It will cost a bit more than a battery, but may save you from buying needless batteries in the future.  I finally broke down an bought one, but note that I was still having the problem after the 1st recalibration.  By trial and error (and maybe a vague memory) I put my MAC in sleep mode, that dropped the load to stop the lights from flashing.  Then I recalibrated with a 22% load and now it finally seems better (lights no longer flashing).  This was with a Smart-UPS 1000.
Let me know if that helps.
Posted on May 09, 2009
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SOURCE: My radio keeps blinking date and time over and
I bought a new one.
Posted on Jan 04, 2010
How do I get the display to stop blinking?
The blinking display indicates the clock has to be reset. If you follow the reset procedure and the display continues to blink, the clock is defective and should be replaced.
Feb 14, 2016 | Audio Players & Recorders
Flashing clock after dead battery?
The car manual will tell you how to reset the clock. Or contact the dealer OR
go to manufacturer web site for manual download.
Nov 18, 2015 | 2006 Renault Scenic 1.9
After a power outage, the oven control light keeps flashing.
You have too reset clock pressing two buttons works for me
Nov 09, 2015 | Ovens
Why won't clock stop blinking?
There has been a power interruption and it needs to be reset, even though the display may be blinking the approximate correct time.
Aug 17, 2015 | Audio Players & Recorders
My engine light is on, the brake light comes on and the speedometer stops when that happens, my key is stuck in the ignition, and the blinking arrow won't stop blinking. I am a first time volvo owner. I...
Brake light comes on auto each time you start the car (saftey check) and will go off when you press brake pedal.
Blinking arrow will stop when you click seat belt together (driver)
turn ign off press key in towards drive stem and turn anti clock (5degs)and pull out
Put in key hold in mileage reset button and turn key to on (dont start the car )the last click before starting (and keep finger on miles reset button till flashing stops
then turn off ,this resets all service lights,
tc
Oct 02, 2010 | 2000 Volvo S70
Trying to set the time on the clock. This device is about 10 years old and I have not instuctions
yorx model 5285 clock radio cassette player , the clock keept blinking and cannot set it.
Nov 05, 2009 | La Crosse Radio Controlled Atomic Clock
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Jun 13, 2009 | 2007 Honda Accord Sedan
Reset check engine light
First of all, you should'nt do this unless you know what the problem is.. or what tripped it. I had this problem when my husband and I were replacing a head unit and disconnected the old head unit, a/c and other stuff then turn the car on. This made the light flash. The first time we took it in and got charged $50 to reset it. The second time we did this procedure and it worked.
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Reset Check Engine Light Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
-Christine
May 15, 2008 | 2007 Nissan Murano SE
27 people viewed this question
 Grubhead
Grubhead
