Microwave Ovens Logo
April Metcalf Posted on Dec 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace clock display on #KBMS1454RSS
I have ordered the needed part but need instructions on how to replace the clock display and to remove the top front panel of the Kitchenaid microwave.
William Miller
Level 3:
  • KitchenAid Master 9,179 Answers
  • Posted on Dec 12, 2012
William Miller
KitchenAid Master
Level 3:
Answers
9179
Questions
Helped
4479586
Points
21747
You can find helpful exploded view diagrams here.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Feb 03, 2008
SOURCE: micriowave key panel
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off. You have to make sure all the old adhesive is off.
Then peel the backing paper from the new keypad and carefully press the new keypad in place. You need to be precise - you cannot apply it, peel it off, then reapply it.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
THENTHEREWER
Terry Rodgers Jr.
  • 131 Answers
  • Posted on Nov 08, 2008
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 25, 2008
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on Apr 22, 2009
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Anonymous
  • 5911 Answers
  • Posted on Sep 16, 2009
SOURCE: Handle broke off my GE Advantium 120 microwave
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
1helpful
Need to set clock
normally in the display you have clock: put the right time that you need to put entering with the keypads, and then enter+clock and ready. However will be a good idea to read you owner manual for better instruction. if you do not have it. download for free.
www.fitness.manualsonline.com
God bless you
Kitchenaid microwave mondel #KBMS1454RSS seems to have a short somewhere
see the information attached and test the main component for SHORT. God bless you
Right side off of touch pad not working
On some models you can order separate keypad, on others you have to order the control panel frame, which has a keypad already installed.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
Let us know if we can help further.
How do I replace the lightbulb on the Microwave ? 1454SSS
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
My microwave stopped working. The light is on inside the power supply is hooked up but the key pad does not function
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
For models KBMS1454RSS0 & KBMS1454RSS1, the following are the keypad part numbers, which you can order from the Pros here:
8205667 Black
8205666 White
8205668 Biscuit
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The door handle on my microwave broke off at bottom of the door. The screws holding the handle on are not visible from the back of the door. How do I access the screws to replace the handle. GE Profile...
The back of the door will have a moulded surround that will be fixed with allen heads or small screws. Remove the inside cover of the door and you will see the holes for the handle.
KBMS1454RSS 1000 watts it just quit no warning
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kithcenaid/Whirlpool owner's manuals and installation instructions here.
I have a kitchenaid model kbms1454rss-o and the pin that makes the turntable turn is gone. i need a new one where can i buy one without having a repair man come out
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
