AEG LAVAMAT 63742 VI E51 error
Washing two towles m/c stopped and would not drain and will not start again i think it was a unbalanced load i have cleaned all filters the m/c is only two years old is there a reset button? regards steve,
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Posted on Dec 01, 2008
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
SOURCE: AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Posted on Feb 01, 2010
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
Wont drain with a load, but will drain when empty. Have cleaned filter, have run drain cycle with filter open motors works. have filled using start of 32 min cycle, and emptied using drain, at l
sounds like inside the drum a dog waste bag or a small plastic bag for something plastic has melted onto the heating element
this can be removed for checking not easy bit fiddly but at least you can rule it out
ah you think i didnt have plastic in my wash
got kids?? then the soap drawer is the place all dirty things go to get washed
sounds like some plastic flapping about above the drum drain port
Nov 28, 2014 | Candy Washing Machines
How do I rectify the UE code , I have finoished my wash but it is still showing up
Hi.
US means unbalanced error. Try balancing the unit as explained on the owners manual. Try redistributing the load. Check the floor. If that does not work try following the instructions in the diagrams for the specific code available on the LG support website. Here the link.
Regards.
Ginko
Sep 06, 2011 | LG WM-2077C Front Load Washer
Frigidaire Front Load washer will not drain nor spin? Help! Washer will start and water will enter unit, however clicking occurs and no spin of clothes.
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Mar 12, 2011 | Frigidaire Washing Machines
The machine is not draining water - it starts the washing cycle, takes in the powder and churns around but then stops when it needs to drain the water. If I empty all the water out, it will then spin the...
Good luck.
Jan 10, 2011 | Asko W6021 Front Load Washer
It starts to spin slow then quits.
Good luck.
Jan 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Water won't drain from the tub, think the hose may be clogged. Is there any way to clean the hose without completely dismantling the machine? It does spin but the water won't completely drain out. We...
Good luck.
Jan 10, 2011 | Frigidaire FWS833A Top Load Washer
I have a aeg lavamat turbo washing machine .when start it the water does not got to the drum ane water never stops simply running
You have a syphon - the waste pipe is probably too low and the end sits in water in the drain, meaning the water runs through the machine and out the waste.
Jun 30, 2010 | AEG Lavamat 12710 Front Load Washer /...
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
