Question about Craftsman Garden
Manual for a Craftsman 6.75 Torque Rating 22 in. High Wheel Trimmer - CA Model
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
  • 26 Answers
SOURCE: High Wheel trimmer starts but won't run
Check inline fuel filter..blocked with sediment.
Posted on Sep 09, 2009
rycgl
  • 1545 Answers
SOURCE: I have a Craftsman High Wheel trimmer that will
Lots of things can go wrong with fuel delivery on these machines. carbon builds up[ in the engine and muffler system...ethanol laced fuel helps break down the sensitive carb parts and especially the fuel lines.
If you feel like it,open up the carb and take a look inside for any debris especially on the real fine mesh screen on the fuel pump side under the mylar diaghram. Check inside the fuel tank for a bad/dirty fuel filter and/or brittle fuel line...Fuel lines develop cracks and holes, thus leaking air and affecting the carbs operation. A rich mix starts these engines but if the mix becomes too lean, they won'd idle and if you run them too long this way you can cause engine damage due to the lack of gas./oil used with so much air entering the system. Don't be afraid to look around and poke around for other problems. Pull the spark plug and either clean it real good or replace it. It gets a build up on it sometimes that needs to be removed (especially down around the electrode insulator (the white part under the tip).
Posted on Jul 10, 2010
rycgl
  • 1545 Answers
SOURCE: i have a craftsman 22" weed trimmer. is the
No, you have to manually control that yourself.
Posted on Dec 05, 2010
  • 144 Answers
SOURCE: All I need to know
You can find a diagram for your mower here. You should be able to remove the top cover, then loosen the tensioner pulley and pull the belt right off. Put your new belt on following the original belt path. You can find a replacement belt at PartsBuggy.com here.
Posted on Nov 05, 2011
Craftsman 22 in. electric Bushwacker hedge trimmer handle is broken where can I get part number?
Call your local sears store for their national parts department 1/800 toll free phone number.
Then write down the MODEL number [and a serial number if available]. Then call the parts department, give them the model number and they should be able to give you the part number.
Just to be as fully prepared as possible, have the actual trimmer with you during the calol so that you may be able to answer ID questions the parts tech may ask.
Apr 23, 2014 | Craftsman 22 In. Electric Hedge Trimmer
I have a craftsman 22" weed trimmer. is the
Dec 04, 2010 | Craftsman Garden
I've got a craftsman 22 in. hedge trimmer (electric) and I'm looking an attachment to enable me to trim my hedges, which are approx. 8' tall, without climbing up on a ladder to trim the tops of the hedges....
Un less your trimmer is a split sharft model ie you can take of the blade by undoing a handle then the answer is no you will have to buy a diff trimmer
Jun 28, 2010 | Craftsman 22 in Hedge Trimmer
I have a brand new Crafsman 22" Rear Bag Front Propelled High Wheel Lawn Mower with a key start. It worked fine for about 20 minutes but then would not turn off once the power lever was released. It just...
It sounds as if the connector for the handle harness became disconnected. Check the wiring connectors and see if one of them came apart. (including the switch...) If it is not that simple please provide a model number and I will dig in the manuals to do what I can do to help you.
Thanks for using FixYa.
Kelly
May 30, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Garden Logo
506 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
