Question about Canon PIXMA Office Equipment & Supplies
How do i remove print head canon ip4800
And clean
SOURCE: How to remove printhead from canon i860
The gray-colored arm (it's not that small) is to the right of the cyan cartridge. It is the arm or extension of the gray-colored hinged cover. Remove all ink cartridges, lift the gray-colored arm up, and pull the print head out. Clean the print head with a cotton ball soaked with water or rubbing alcohol. Dry and re-install the print head.
Posted on Feb 29, 2008
SOURCE: How do I remove a Canon 730 Multipass print head
Press the button on the right hand side of the printer. Lift the lid, pull up the little gray handle. Rock the print head container a bit and you'll see a little metal bar. Grab that and pull straight up.
Posted on Jun 13, 2009
SOURCE: My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Posted on Jun 14, 2009
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Posted on Jul 08, 2009
komguy
  • 2306 Answers
SOURCE: How do I remove and clean the print heads on my
With power on, open the top cover and wait for the head to come to the center, after removing the inks, lift the gray handle on the left side and lift out the printhead. The top leans toward you first, just lift it out. Soaking in warm water about 1/4 inch deep overnight is the best cleaner.
Posted on Aug 11, 2009
Blurry colorwashed photos from canon pixma pro9000. What can I do to fix this?
Hi there, I located this video about removing the print head and cleaning it. I've had to clean my print head from time to time, so take a look at this video and see if it can give some help. Your printer might not look exactly the same, but you should be able to remove the print head. If cleaning the print head doesn't clean up the color issue, try contacting Cannon support: Canon Contact Us. I wish you best of luck!
-Mr. W
Feb 25, 2015 | Canon PIXMA Pro9000 Printer
Remove print head canon mp480
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Dec 31, 2012 | Canon Pixma MP480 All-In-One InkJet...
Yellow ink will not print
You may have blocked yellow print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
May 22, 2012 | Canon Office Equipment & Supplies
A paper jam on my canon ip4800 caused the print to be misaligned. now the edges are not straight. help!
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Sep 06, 2011 | Computers & Internet
Inkwells are full, i have run through the auto cleaning process and still no print how do i clean the nozzles
If your Canon has a removable print head as many of them do, remove the print head and set it with the head sitting in an ounce or two of household ammonia overnight and flush under running water. Our Canon doesn't get used enough to stay clean so this has to be done fairly often if we need to print anything. If any residue remains, try a low-fiber paper towel with some window cleaner to gently scrub the printing surface.
Dec 27, 2009 | Canon S200 InkJet Printer
It doesn't print in black but prints in color
Hi, To ensure this is only an issue with the black, I recommend printing off a nozzle check. This will show you if this problem is effecting any of the other colours.
To print a nozzle please refer to chapter 12 page 115 of the manual,
If colours are missing I recommend cleaning the print head. You have two options for cleaning the print head a normal clean and a deep clean, start by doing a normal clean if required try doing a deep clean.
You can download the manual here:
http://www.fixya.com/support/p360568-canon_multipass_mp390_all_in_one_inkjet/manual-10203#
Dec 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Instructions to clean print head of Canon iP5000 printer, please.
Try first with cleaning tests on maintenance mode.Make sure all cartridges are not empty.If not help try manually cleaning.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.
Nov 23, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
How do I remove a Canon 730 Multipass print head to clean it? The Black ink isn't printing - I've cleaned the print heads using the software, but now need to remove the print head and clean it manually...
Jun 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
396 people viewed this question
old marine
old marine
