Question about Vacuums
The handle comes off my Hoover Wind Tunnel PAWS vacuum model #UH702010
The handle to the vacuum comes off while being used. There is a screw that is about 3 inches below the handle holder that comes out. It looks like a bolt goes on the other end and it is missing. I've tried searching for it in parts stores and can't fine it.
reddevil6
  • 1673 Answers
SOURCE: Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Posted on Jan 22, 2008
  • 4 Answers
SOURCE: Hoover Wind Tunnel ON/Off Switch
Replace the rocker switch inside the handle. Part #28161067, it's about $2.50.
Posted on Jul 19, 2008
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
I need to replace the actuator pivot arm on my Hoover Wind Tunnel to fix the self propel feature. I can see where it needs to go but I can not seem to get the cover off the vacuum so I can get to it. How do I do this?
Posted on Sep 16, 2008
SOURCE: replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Posted on Jan 03, 2009
  • 294 Answers
SOURCE: Filter in Hoover Wind Tunnel Vacuum
Definitely not. Do not use water or any liquids to clean it. Te normal use life is 2-3 years keeping it maintained. You can clean it dry with the dust brush from your vac attachments. place in a plastic bag and tap it some folks even us an air compressor to blow out the impacted dirt. you will only want to use the Hoover brand, other generic brands dont fit as well.
Posted on Jan 17, 2009
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hoover wind tunnel 2 bagless vacuum not working
Place handle in low position and turn cleaner over so bottom side is up.
Remove the 4 screws in bottom plate and lift off.
Look on the left side of the agitator brush. You should see the belt there. Remove agitator brush roll and used belt.
Discard belt.
With lettering on outside of belt, slide new belt over motor pulley.
Insert agitator though belt and place belt in belt guide on agitator.
Grasp agitator firmly and fit it onto position by first sliding end opposite the belt into the rectangular slot on side of cleaner.Pull other side of agitator into place
Turn agitator making sure belt is not pinched between agitator and agitator shield.
If this does not take care of your problem, then check your filters for dirt and your entire vacuum for blockages. Both filters do come out. If you can't get a new filter right away you can gently clean the paper filter and remove a lot of dirt. (I recommend outside)! The other filter is washable.
Make sure it is well dried before replacing.
Good luck.
Aug 06, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover wind tunnel vacuum will not turn off
You will have to replace the switch, Takeout the 4 screws on the back of the handle, it will slide off, then from the front, take out the 4 screws that hold the tool compartment on, it will then lift off and you can access the switch.
Jan 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Model number U5763900 Serial Number 090400013588 Handle broke off just above the four screws that attach it ti the boby of the vac. Hoover does not list parts for models that are more than two years old....
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=658103
Generic problem for all Vacuums
Posted by rlholif on Jun 09, 2008
Model number U5763-900 Serial Number 090400013588
Handle broke off just above the four screws that attach it to the body of the vac. Hoover does not list parts for models that are more than two years old. The vac operates perfectly but without a handle my wife cannot use it, where can I find a part replacement. Easy to remove four screws and replace. Don’t want to drive 100 or more miles to find an authorized repair shop. Oh yes, this is a Hoover Preferred Wind Tunnel Bagless
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You have all the information needed but I would contact your local vacuum cleaner dealer and they may have a good used one or they may stock a new handle for your you or they can ship you one If you live too far from a factory authorized dealer. The vac shop that I worked in always had good used parts for ½ the price and it worked just fine – the only difference was the color and for the handle that would not make a difference in the performance and your wife could use the vacuum again. Also Hoover can ship the part to you providing they have it in stock. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
Wind Tunnel Model: u6630900
Need a manual for Hoover Vacuum Cleaner, Wind Tunnel Model:u6630900
May 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Problem with vacuum suction in upright position
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Apr 11, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
