Question about UTStarcom CDM7025 Cellular Phone
If I don't know the last four digits of the assigned phone # how do I get around the lock code? i have a cricket phone and i forgot my security code to it and i need to unlock it and it will not unlock i need help of how to unlock it
I had this happen also and i had my number changed then my cuzin locked my but my code changed to my new # try the last 4 numbers of the new number and try the hole number with out the area code..
Posted on Mar 21, 2009
That's what the lock is for-to keep folks like you that don't know the phone number of the code from getting access.
Posted on Mar 19, 2009
Samsung r261 shuts itself off
Pl try resetting it.The procedure is as follows:
  1. Press the Menu softkey > Settings > Phone Settings > Security
  2. Select Security
  3. Enter Lock Code
  4. Note: The default lock code is the last four digits of your mobile phone number
  5. Select Reset Phone
  6. Press Yes
SCH R261 Chrono FAQ List Cricket Samsung
Jun 14, 2014 | Samsung Chrono R261 R 261 Cricket Camera...
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
I need to reset my phone, but im locked out. How do I reset it if it's locked and I don't know the code?
What is your mobile and model ?
If you forgot the security code you have to reset you mobile. Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means just visit here Simpleunlocking.com for the master reset code service and get the reset code........
May 14, 2012 | Cell Phones
Forgot lock code for lg vx3100
hi..
To lock the phone:
  1. Press the left soft key for Menu.
  2. Select Settings then press OK.
  3. Select Security then press OK.
  4. When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number).
  5. Select Lock Mode then press OK.
  6. Choose your preferred option then press OK:
    • Never
    • On Power Up
    • Always
To unlock the phone:
  1. Press the right soft key for Unlock.
  2. When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number)
thanks for rating
Jun 02, 2011 | LG VX3100
I forgot my cell phones pass word and need to unlock my phone what can i do?
  • 1
    Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones.
  • 2
    Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN.
  • 3
    Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number which is under the battery. Reinsert the battery and power on the phone. Enter the last 4 digits of the IMEI number on the PIN entry screen. The last 4 digits on your IMEI number can occasionally be the service providers preset PIN for the cell phone.
  • 4
    Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and Social Security number.
  • 5
    Turn off your phone. Hold the keys "3," "*" and "Call" and switch the phone on. Hold the three buttons down until the word "Formatting..." appears on the screen. This should reset the phone lock code
  • Dec 18, 2010 | Lands Phones
    I HAVE A CRICKET PHONE AND I NEED TO UNLOCK IT
    Sometime Its hard to unlock cricket phones but did you try the last four digit of your phone number? if still no luck. than dial ##626*. the phone will ask you for 6 didgit code, put 333333 and than goto MDN and change the last four digit of the phone number to 0000. Exit the setting. let the phone restart. you lock code should be reset to 0000 now.
    Mar 11, 2010 | Motorola Mobility ROKR E6 Smartphone
    I need a 4 digit unlock code for my samsung r560 the service provider is cricket communications can you please hlp me
    For all Cricket phones (and many other carriers) the default lock code is the last four digits of your cell's phone number. Once you go into 'Security' and enter this code, youu'll be able to change it to whatever you prefer.
    Mar 04, 2010 | Cell Phones
    Forgot Lock Code - Samsung m500 Cell Phone
    try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
    Mar 23, 2009 | Samsung SPH-M500 Cellular Phone
    Security unlock code
    there are various sites available which provide you unlock code if you know your imei no(15 digit).
    simpler way is to go to professional software repair person, he will just do it for you
    May 07, 2008 | Motorola Mobility RAZR V3
    Forgot
    The lock code's default is the last four digits of the phone number assigned to it, but if someone changed it or you changed it and forgot it there really isn't much you can do short of going to a cell shop and having them reset the firmware.
    hope this helps
    http://pchelpforanyone.blogspot.com
    Mar 07, 2008 | Sony Ericsson Walkman® W880i Cellular...
    UTStarcom CDM7025 Cellular Phone Logo
    333 people viewed this question
    Top UTStarcom Cell Phones Experts
    iphone service
    buzzcola
    Level 1 Expert
    Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
